My Beko WM1510W is working fine except for one thing when the drum spins there is an almighty rattle from somewhere inside. I have taken the back and top off, there is no extra movement in the machine,other than this rattle. I believe it might be the bearing, can anyone help?
Hi there.....this rattle can usually be associated with failed or failing bearings.......simple test to follow....with machine switched off and door open...put your hand in and try lifting the inner wash drum...there should be NO MOVEMENT...movement indicates failing or failed drum bearings
regards Sir Galahad
