Beeping I don't get a code error, My signal for the loud and soft when washer is done keeps beeping. It will be beeping all during the washing time. Sometimes I have to keep turning the washer on and off cuz it won't start
my machine keeps beeping; it beeps during the wash; it won't stop. Now the machine won't do anything but beep.my machine keeps beeping; it beeps during the wash; it won't stop. Now the machine won't do anything but beep.
my machine keeps beeping. It beeps all through the wash. It now won't wash at all.my machine keeps beeping. It beeps all through the wash. It now won't wash at all.
AnonymousNov 15, 2008
I am having the same problem. The soft/loud signal keeps beeping. I turned my washer off and now it won't start up again.
My washer and dryer is 2 years old and 4-5 months ago I had to have the dryer repaired, basically the same thing. These are suppose to be the best but they are nothing but trash!
You can't post conmments that contain an email address.
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
Jan 16, 2015 - 6 posts - 2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
If its the main board that you are having an issue with, honestly i will suggest to get a new one instead, might cost you as much as buying a new one if you are going to have it repaired.
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
This is a common and very well known problem with the Oasis. You will need to replace the operator interface board inside the control panel to resolve this issue. The board is located directly behind the control knob. If you post back with your model number, I can research a part number for you, give you info on where you can order a replacement, and give you guidance on how to replace the board yourself.
You said,The cycle signal keeps alternating between loud and soft on its own and
the other buttons will not function while this is happening, including
the start button.
You could have a bed signal switch or control panel . if the below suggestion failes or the problem returns you will need service! Try unplugging the washer for 5 minutes and then restart it. This should reset the system if there is a glitch like in a computer! Sounds like we need to try to reset the system!
Huuum At your service! Lets try this, Like with an error code. This can reset the system if it is electronic! Unplug the washer and wait a 5 minutes then restart it. If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange! Usually it corrects some error problems if they are not serious. Or they are sometimes just a glitch.
Let me know how it works! Waiting for your reply! Please remember to leave a rating when you are done! Thank You huuum
all i can figure is it is a strange method by kenmore to alert the user to throw in an antistatic cloth that gives softer clothes (clothes softener sheets)
