It says to strike F1 key to continue, F2 to run the setup utility. But when I click F1 it says that windows could not start because the following file is missing or corrupt: \windows\system32\config\system. You can attempt to repair this file by starting windows setup using the original setup CD-ROM. SELECT "r" at the first screen to start repair I really need your help.
Use your system restore disks to repair your computer since the OS is FUBAR
Without those disks you are SOL. And if you never made them or lost them, now you have learned first hand why it is so important to have them.
Go to the dell site and see if they have your original OS in an iso file for installation. If so that will save your sorry b---.
SOURCE: Dimension 3100 Won't Boot
Try remove the hard dirve and then fix it back. and if the system prompted you to strike F2 then go . In the bios setup. load the " setup bios default and press "F10" to save and exit. the computer will restart.
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
SOURCE: dell dimensions 3100
sounds like your floppy drive is failing, you could get it replaced or simply turn it off via the BIOS.
to turn it off simply hit the F2 key. On the first screen usually it will list your Hard Drives, CD ROMs', and the Floppy. scroll down to the floppy and hit enter ot the corresponding key form the bios's legend at the bottom or right hand side of the screen untill you see disable.
Next you can navigate to Save & exit or hit F10 to do the same. G/L.
SOURCE: my dell dimensions e310 is
1 . Insert your Windows installation CD. Reboot the computer. Your computer detects the boot media in your drive and asks you to press any key to boot to the Windows installation disk. Press the space bar on your keyboard. A blue installation window is shown.
2 . Press the "R" key to start the Recovery Console process. Press the "1" key to open the command line console. You are prompted for the administrator password. Enter it into the console and press "Enter."
3 . Type the following text into the command line:
copy e:\i386\ntldr c:
4 . Replace "e" with the drive letter for your CD-ROM drive. This command copies the NTLDR file from your installation CD to your hard drive
5 . Remove the CD from the drive and reboot the computer again. The Windows operating system should successfully boot.
Thanks for using Fixya.
