Orange light blinking 5 times
SOURCE: Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
SOURCE: Orange light blinking
Hey guys, I finally brought my ip4500, not ip4300 1month ago, and am having the same problem. I experimented with the printer inks. And finally i have fixed this problem. I suspect it may work for ip4300, or other similar pixmas as well. Please follow at your own risk.
Scenario:
The printer error led flashes 15 times. And, The ink tank lights are flashing endlessly, or does not light up at all. If the ink light is off, it does not mean that the chip is corrupt.... Do not replace it, like i have. lol.
Problem: one or more of the inktank chips are corrupt. If at least one cartridge is corrupt, the printer will not work. Must purchase corrupted ink cartridge, or call canon for replacement.
Solution: Instead of buying a complete set of ink, find out which ink cartridge is corrupt, and needs replacing:
1.put all ink tank into the printer without the chip. close printer cover. computer should alert that "the following ink tank cannot be recognised. Printing cannot be executed because the ink tank...." You should see a picture of the ink in the alert box.
The picture in the warning box shows that the black, black. yellow, magenta, cyan are not inserted.
2.Starting with the blue ink, remove blue ink from the printer, reinsert chip into ink tank, then put the ink tank back into the printer. Close Printer cover. Notice that this time, if the ink chip isn't faulty, computer alerts that only black, black, yellow, magenta are not inserted into your printer.
If it is faulty, then you see another alert box, about unrecognized ink - if so go to step 4.
To test if the chips on the other ink cartridges(tanks) are faulty:
3. Repeat step 2, with the rest of the ink tanks. from right to left(blue, magenta, yellow, pgiblack, black)
4. Purchase corrupt ink tank. or call Canon for a replacement.
lemme know if this helps you.
SOURCE: blinking light
it means ther is a spool jobs that was sent to the printer, hit the cancel button on your printer and check also your pc for any queued job cancel all file and start again.
hope this helps
SOURCE: why flash by 5 times the orange led?
Probably your waste ink counter should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Good Luck, I hope this helps?!
SOURCE: ip 4200 blinks 5 times
This error is the print head is not installed
[1401], or it is not properly
installed (Print head temperature
sensor error [1403] / Faulty
EEPROM data of the print head
[1405]).
