That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
SOURCE: I have a Mitsubishi hd 1080 series 60 inch model # vs-60111
G'Day!
What you're describing is a repair issue. Unfortunately, there is nothing you can do through troubleshooting to correct that problem. There is an internal part that has to be replaced. If you're under warranty or have an extended service plan, the repair will cost you nothing.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please post a comment if you need further assistance so
that I can help you further.
SOURCE: mitsubishi ws-55809 needs new red tube
you can get a red mitsubishi tube at the following link and it comes with free shipping. If youre not sure which one to order, leave them a email and they will respond quickly, just let them know your model number and what youre needing. they are listed under the projection CRT catagory on the left side of their page. Here's the link.
http://servicemanuals.vstore.ca/
SOURCE: mitsubishi HD 1080 series model ws-65807 no volume.
You need a remote. There are places that sell them, but you can usually get by with your cable box remote or some other modestly programmable remote. It would help if you had an owner's manual. You can probably find one on line. It is a bit of a dance to make the menus work correctly.
My set is gone, but you have fairly ordinary on-screen menus. One of them is for sound on or sound off to the internals. That so that there isn't the conflict between speakers from a receiver based audio setup. You should have external speaker outlets on the set itself. If you do, plut in a speaker you're not worried about. you should get sound out from there.or use an audio out connection to a receiver, etc.
SOURCE: Mitsubishi Model # WS 65311 HD 1080 turns on then shuts off.
try holding in the menu and input/device buttons on the front of the set both together and see if it blinks a series of blinks, pause briefly then blinks a second series of blinks, let me know what the blinks were sush as 22 or 24
SOURCE: Mitsubishi big screen Model ws-55809 shuts off after powered.
two possible problems:convergence IC(2pc),or hi voltage output:transistor,flyback,capacitors.
