Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV8600 high pitched squealing noise when going into spin cycle and a slight burning smell
3 Suggested Answers
6ya staff
SOURCE:
mumma_1
Debs
  • 903 Answers
SOURCE: maytag atlantis mav6000
sounds like the carbon brushes need replacing in the motor, they can cause a screeching sound as they wear down.
Posted on Oct 26, 2008
dh1200s
dh1200s
  • 335 Answers
SOURCE: Maytag machine, will not spin to drain
Hello chuckf206 ,
Sounds like the roller clutch bearings in your machine are seized/rusted up. Do you want to try to DIY the repair?
Read thru this post for the details of what is involved. Post back with any questions. Rich
Posted on Apr 26, 2009
My Maytag Top Load Washer was in the beginning of the wash cycle with a large comforter when it began squealing, sounded like from a belt within the machine. I smelled a burning smell and stopped the...
The belt has been ruined. Basically there was to much load on the belt. You will need to replace the belt, maybe a 20 dollar fix and should take no longer then 15 minutes. Just make sure that before you go to the parts house, your remove the old belt and take it with you along with the model and serial number of the machine.
Please rate.
May 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
High-pitched squeal/whistle noise from range
Noise went away by itself. No root cause found. Please remove this posting, thanks.
Dec 04, 2009 | Maytag MGC6430 Gas Cooktop
My MAV8600AWW top load washer makes a loud steady squeal whining noise in spin cycle. Load size doesn't affect noise. Machine is 7 years old. Any guess as to problem?
Maytag had problems with the berrings on the transmission . water gets in and the berring goes bad rorring as it spins. Dump it and get a Whirlpool.
Nov 11, 2009 | Maytag MAV8600 Top Load Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Hello chuckf206 ,
Apr 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag atlantis mav6000
Oct 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis shut down during rinse cycle.
Contacted a local repair shop. They told me that if I got it spinning again, the motor was most likely ok. It is protected by a thermal switch that turns it off when it begins to overheat. The smell was to be expected as it was overheating; the difficutly restarting was because it hadn't cooled off enough yet. We have now used it a few times for small loads. Still getting a smell, but the wash cycle is completing ok.
Jul 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
SQUEAKY DRYER
HOW DO YOU ACCESS THE REAR DRUM TO APPLY THE OIL?
Feb 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MAV6000 Top Load Washer Logo
59 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
