When screen comes on, shows rectangle boxes all over screen, after it warms up, has 1'4" vertical lines on screen. Still has a sharp picture, though.
SOURCE: Sony Grand wega KDF-E50A10
unfortunately the B Box assembly needs to be changed in these and price of the part alone is more than half the cost of a new tv
SOURCE: different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
SOURCE: Vertical dark line down screen
http://www.avforums.com/forums/sony-owners-forum/1165140-faint-lines-kdl32s5500.html
I have also experienced the same problem on two occasions, but my Sony TV KDLV3000 has actually been backwards and forwards on three occasions to be repaired. I have had a new control unit and will be having a second screen replacement shortly. I have contacted my local Sony Centre and they have stated that they will only replace the TV if there are THREE IDENTICAL faults.
COME ON SONY CENTRE GET YOUR ACT TOGETHER AND TAKE A NOTE FROM JOHN LEWIS THERE CUSTOMER CARE IS SECOND TO NONE.
Not sure I'll buy a Sony again after this experience having been a loyal Sony customer for a number of years, will probably look at a Samsung or LG next time.
Testimonial: "Thanks for your comments. Very useful."
SOURCE: My Sony KDL-32XBR4 has vertical lines for 5-15 minutes on startup
I have a 46 inch , Sony XBR 4 tv . The past week there has colored vertical lines that appear on the screen for about 10 minutes . Then they go away . What is the problem and solution?
