Question about Westinghouse SK-32H540S 32 in. LCD TV
My tv turns on for 10-20 seconds then the orange light comes on
    Top Expert:
  • Westinghouse Master
  • 14,553 Answers
Isee so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking
voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed
my tv turns on for 10-20 seconds then the orange l - 4_3_2012_4_12_02_pm.jpg
Look on the power supply board in the set for puffed up and bad caps like these.
Posted on Apr 03, 2012
6ya staff
SOURCE:
Turns off after about 20 seconds..
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 18, 2015 | Vizio Televison & Video
My TV is not turning on the red light is showing but the TV is not coming on
If u have an orange light, try holding down the power button for 15 seconds to reset. Light should turn blue shortly after that.
Sep 30, 2013 | Westinghouse Televison & Video
My Vizio VX37L HDTV won't turn on. Was watching it one day & it turned off by itself. Replaced power supply with new one with no luck. Orange light comes on but will not turn white.
reset the tv with the tv off, but plugged in hold down the soarce botton on the tv for 5 seconds it should click on and work. if not then there may be curcuit board issues. i found the same tv on the side of the road as somewone was throwing it out, it was leaning aganst their trash can. i brought it home. plugged it in and it went on and inediatly went to the orange vizio light. i rest it and it's been perfect ever since is my comoute monitor now...good luck i hope that fixes it for you..
Nov 25, 2012 | Vizio L37 Television
Have PT50LC13 that will not light up when power button is turned on. The power button just blinks orange 5 times consecutively with a 2 second delay between intervals.
The light flashes 5 times consecutively with a 2 second delay becuase it denotes there is some internal problem in the TV.So please consult your near by service centre.They will come and fix the problem.You cannot do anything .
Thanx
Jul 23, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
When i turn on my tv the light turns orange green for a few seconds and then turns red and flash's... What do i do?
Jun 18, 2010 | Thomson LCDB 03B 27 in. Television
Thomson 27 LCDB 03B
when i turn on my tv the light turns orange green for a few seconds.
Jan 15, 2010 | Thomson LCDB 03B 27 in. Television
Power Bar has a red light, xbox wont turn on
OK, this is a power supply issue here. you will need to replace the power supply board asap/ it is malfunctioning.
Contact Microsoft for this repair.
Jun 22, 2009 | Microsoft Xbox 360 Console
Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
Mar 06, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse SK-32H540S 32 in. LCD TV Logo
59 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
