SOURCE: jensen UV10 screen wont work
this is a big problem with this type of decks,, if its only 2 weeks old take it back to the store!
SOURCE: Can't find Jensen UV10 e-brake bypass code.
Ok what you gotta do is connect the pink e-brake wire with the black wire that is already connected to the radio as the grounding.
UV10 Works 100%!!!!
Greetings from Montenegro
SOURCE: bypass code that works for playing video .
ground the yellow wire and then it will always play regardless of the gear its in
