it seems like your tv remote and your dvd remote are progamed pertty much the same. What you have to do is put some carboard over the eye of the tv so when you hit the remote it will not change the chanels on the tv. I had that problem with my tv box and tv. I would change the chanel on the tv box and the tv would go off. so I had to cover the eye on the tv so it would not change when I used the cabel remote
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
hi, There can be two possibility for this problem. Lcd driver (T-CON board) or the lcd itself faulty. In most cases the lcd driver will become faulty. I have added a picture bellow. There is a circuit board inside your tv like this Covered by a metal cover. Remove the metal cover. You will see there will connection on three sockets. of which 2 will go to the lcd panel and one will go to the mother board. Before replacing that board carefully remove the wires from the sockets and then reconnect the same. some time improper contact can cause this problem.After that check the tv. If then also the problem remains you have to replace the T-CON circuit board . Have added the picture of T-CON board for your refference. ok
hi
hope u didnt touch enything in there
30,000V is what you get....
after 3 days it will dissolves
anyway you can replace it but you'll need your solder experience in hand
you need to buy a new unit
a good soldering iron
and make them small round and neat
good luck
