Question about Splendide 2000S Front Load Washer / Dryer
Splendide 2000 model# wd802 drains byt will not spin nor turn
Will not spin washes drains will not spin dry
    New Friend:
    Problem Solver:
  • 5 Answers
I have a splendide 2000 / WD802 pre m with round power buttons. It came with a used RV I bought. Everything would work on it except the drum wouldn't spin at all. After some research and messing around with it I was able to fix it! You remove the back panel and in the bottom left corner there is a white control module chip board mounted in by two screws. Remove the two screws from the back for access to fix it. Now the top plug on pin 1 and 2 shoud have 2 white wires connected to pin 1 and one baby blue wire connected to pin 2. I jumped these 2 pins together with a small length of wire and now our machine spins and works great! Be sure to used at least 6 inches of wire at least as thick as the rest of the wires and make sure that it is well connected. I recommend you take the crimps off the blue and white wires and re crimp them with the jumper wire crimped as well. If you don't have a good connection with a long enough wire it will get hot and possibly catch fire so it is very important to do this correctly. I hope this helps someone!!
Posted on Sep 24, 2017
5 Suggested Answers
6ya staff
SOURCE:
Mike
SOURCE: splendide 2000 doesnt work at all on wash
I have exactly the same issue. The door normally locks, but doesn't do anything on wash.
Posted on Aug 14, 2008
Anonymous
SOURCE: splendide 2100 washer/dryer now fails to dry -
Remove the top - two screws in the back then slide forward
In the front right top you will see the air box and the terminals for the heater coil along with other wires and sensors. Start the washer on a dry cycle and check the voltage to the heater terminals. You will be looking for 120 AC. If voltage there but no heat the heating element is bad. If no voltage there follow the wires to the overheat switches and check the voltage on the other side of these switches (round devices with two terminals on top). If there is voltage there then the switch has tripped. Unplug the machine. Look for a spot of paint on this switch, scratch it away and you will see a small hole. Insert a strightened paper clip into this hole and push to reset the switch. Re-power and test the results.
No power to these switches probably means a bad circuit board $$$.
Posted on Dec 21, 2009
Maccoi
SOURCE: Splendide 2000 Model Help Needed
I have the same problem with my WD802 "pre M". I have found this forum and it as helped me some. Here is one forum that might help you - http://applianceguru.com/forum2/17215.html - I think it's my control module, but I cannot find a test guide for my "pre M" WD802 module. I am Calling Splendide first thing tuesday to see if they have a tech manual for the "Pre M" models. Good luck with your WD802.
Posted on Jul 03, 2010
tiger56h
hussein mohd
  • 176 Answers
SOURCE: where can i order a
in D&L STOR
Posted on Dec 11, 2010
Splendide Model WD 802 . Would not drain water.
I have a Splendid Washer/Dryer combo Model # WD802.
The water is not draining. I have taken the filter out, cleaned it, still does not drain. Gets to the drain cycle and does not go any further. Same in every cycle.
Anyone with suggestions for repair ? Thanks
Aug 01, 2011 | Washing Machines
I have a Splendide WD802 and the washer/timer is giving me problems. I beleive the part # is 116102529. Splendide wrote me back saying it is no longer available, but some retailers might still have it. Do...
I have a splendide 2000 / WD802 pre m with round power buttons. It came with a used RV I bought. Everything would work on it except the drum wouldn't spin at all. After some research and messing around with it I was able to fix it! You remove the back panel and in the bottom left corner there is a white control module chip board mounted in by two screws. Remove the two screws from the back for access to fix it. Now the top plug on pin 1 and 2 shoud have 2 white wires connected to pin 1 and one baby blue wire connected to pin 2. I jumped these 2 pins together with a small length of wire and now our machine spins and works great! Be sure to use at least 6 inches of wire at least as thick as the rest of the wires and make sure that it is well connected. I recommend you take the crimps off the blue and white wires and re crimp them with the jumper wire crimped as well or solder the connection. If you don't have a good connection with a long enough wire it will get hot and possibly catch fire so it is very important to do this correctly. I hope this helps someone!!
Apr 02, 2011 | Splendide Washing Machines
Jun 29, 2010 | Splendide 2000S Front Load Washer / Dryer
Kariba WD 802, need a part number for the Wash/Dry Selector Timer. The machince works properly when manually rotating the timer, it will not advance on it's own.
head over to repairclinic.com and enter your model # for a complete parts list.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Splendide 2100 Vented Washer-Dryer
Splendide 2000 doesnt work at all on wash
Jul 29, 2008 | Splendide 2000S Vented Washer/Dryer
Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
Washer fills, drains, & final spin
Make sure the tub us actually moving. Sounds like the belt may have come off. That is what has happened to me.
Splendid
Check first here WD850J.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Feb 19, 2008 | Hotpoint NBXR463EBWW Electric Dryer
Splendide 2000S Front Load Washer / Dryer Logo
975 people viewed this question
Top Splendide Washing Machines Experts
Marvin
Marvin
Ekse
peter gittos
peter gittos
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
