Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Testimonial: "I finally got it started after draining the gasoline out and replacing with new gas. It only runs with the choke engaged, but I'm going to seafoam the carburetor and add it to the gasoline."
if anti back fire selonoid is disconnected how
are you getting fuel? if so ck selonoid again make sure it is open. should run
SOURCE: drain plug on mtd yard machine
the drain plug should be on the side of the engine down near the bottom. They usually have a square head on them.
SOURCE: Mower will not start. Replaced spark plug, air
the key word here is the sound, engine must have compression, put your hand over the carb and try to start, if it trys to **** your hand then you should have enough compression, if it doesnt then you probably have a broken valve- hope that helps
SOURCE: king cat ride on mower
could be the spark ignition module,the flywheel sensor pick-up,a rusty flywheel thats so rusty that can no longer transfer spark impulse to the pick-up coil,an ignition wire or fuse in this circuit,or a bad ground in this circuitry too
SOURCE: Recently bought a 2004 Husqvarna
Hi, I would check the pump out. Air maybe getting in pump. You should get a rebuild kit for pump.
Gasket(s).need to be replaced. cracked or ripped. Hope that works for you.
