I bought a new Samsung ST90 yesterday used it once and went to turn off the camera. An error appeared on the screen saying "The zoom did not operate normally. Insert the battery again and turn the camera on..." After a few seconds the camera then turns itself off. I have inserted the battery multiple times and there is no signs of it working. Is there any way that this can be fixed?
SOURCE: I've bought a new samsung pl121 camera & taken a
Your camera is obviously defective. It may have been a return and resold to you. In any case, you should return it immediately....this problem will only get worse.
SOURCE: My Samsung 5x ES30 Zoom Did Not Operate Normaly
Ensure you're using new batteries and try again.
I tried the paper shim going around between two lenses and body and lens, compressed air, allowing small amount of alcohol on q-tip on gap - and nothing would get my lens to open. Then I held in flat between my two hands and "gently" gave it a very light twisting diagonally, once in each direction. Hit the power button and it works fine now. As my gaffer used to say, "Don't force it! Get a bigger hammer!"
