The fridge section is not cooling and water is coming from the grill at the front .
SOURCE: Indiset Fridge not cooling
If the compressor is running and not cooling then there is no refrigerant circulating in the refrigerator or no air moving across the one or both coils. No ice in the freezer section indicates that no cooling is taking place at all, pointing to a lack of refrigerant rather than poor air circulation due to a bad fan or frozen coil.
You can try a manual defrost to ensure it's not a frozen coil by unplugging the unit for several hours with doors open then starting it again. If there is still no cooling occurring you need to check the refrigerant level. If its low you will have to find and seal the leak, pressure test with nitrogen, evacuate and weigh in the correct amount and type of refrigerant listed on the unit.
Hope this helps, needless to say be sure to find a reputable qualified technician to open and service your refrigerant circuit this will make or break your unit.
SOURCE: LG GR727RB Top Freezer ok but bottom fridge is not cool
Hi softwaredude with an LG GR-727R refrig. The occasional build up of water on the bottom of the fresh foods sections tells me that the refrig is going through it's defrost cycle, but that the defrost drain is plugged. If you take the back off the refrig. you will see a plastic tube about 1/2 inch diameter with a few ribs on it going from the top of the compressor compartment to the bottom, which is a defrost water holding / evaporating pan. Look to see if that tube is plugged. If not, it is plugged further up, most likely where the defrost water drains off the evaporator (that the coils behind the freezer wall that do all the cooling). Take that back panel off and use a hair dryer to melt all the frost off. The frost is blocking air flow from the freezer section to the fresh foods section, thus poor or no cooling in the FF section. You should be able to spot where the defrost water is suppose to drain. If the water is not draining out, use a turkey baster with hot water to flush out the drain.
SOURCE: Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
SOURCE: My Amana fridge #ARB2215CB seems to be cooling the
Your refrigerator probably has an issue with its "damper control assembly", which regulates cold air coming from the freezer compartment. Contact an appliance service company.
Testimonial: "Thanks he is on his way!!! Great work!!"
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
