None of the remote control related to the DVD or even VCR status will work. Time keeps changing. Disk tray will not open and it flashes OPEN. Also, when you press MENU, it flashes please wait. I have unplugged the machine for 2 days and as soon as I plug it back, it goes back to the same thing.
SOURCE: Samsung DVD-VR330: Disk Tray won't open
The solution is to unplug the machine and wait 10 secs. and plug it in again. I have to do this often. another part of the problem may be that some of the blank disks are bad. I got the DVD+R at Staples and about 4 out of 10 were able to be formatted. I am about to try the DVD-RWs.
SOURCE: DVD stopped working and cannot do setup.
You probably need to reset your DVD/VCR/Combo. Go to www.samsung.com. Go to <Support>. In the search box, type in the model of your DVD/VCR/Combo. Or type in, >how to reset DVD/VCR/Combo<. Each model has different reset method and there are hundreds of models!
853. How To Reset Your Samsung DVD Player
STEP 1
STEP 1. DVD Reset List
Samsung DVD
players have a built-in reset procedure that resets the DVD player to the
factory defaults. You can use the reset procedure to reset settings that
don’t work with your TV or to resolve issues such as unit lock up. To run the
reset procedure, you press one or more buttons on the front of the DVD player
and hold them for at least fifteen seconds. The buttons your press depend on
the model you have.
Important: For the reset
procedure to work, you must press the buttons on the front of the player, not
on the remote control for the player.
Below is a list
of all Samsung DVD players and the buttons to press to run the reset
procedure.
DVD511 - Stop
/ Play
DVD611 - Stop
/ Play
DVD709 - Stop
/ Play....
Many, many other models follow but cannot be listed here because of this site's text limitations.
SOURCE: I have a Samsung DVD R160 recorder. A few days
Try this, look for a small hole on the front of the unit.Use a pin and press in to see if it opens,ejects the disk .If no hole try seeing if you can press ,lift,pull at the door/slot while pressing the open door/eject either on the unit or with the remote control.It sounds like you may have a bad CD/DVD (copy) that the unit is trying to read/load but can't. keep trying to eject CD/DVD if this doesn't work unplug unit for 5 minutes,try open door again do press and hold open repeatedly I know it's frustrating but it just may eject.Don't use this recorder for playback of DVD buy a $30 DVD player the cheaper the better they play anything.GOOD LUCK
