No remote
SOURCE: menu wont work, continuos channel search
Usually, this means that something has spilled into the front of the set and has contaminated the pushbuttons. If one of the channel pushbuttons has fluid in it, the set will just sit there searching for channels and will not respond to any other commands. The computer thinks you are pushing the channel button and responds accordingly. When you push another button the computer does nothing because it thinks that you are pressing 2 buttons at the same time. The board should be cleaned and any contaminated pushbuttons replaced by a qualified tech.
SOURCE: channel issue
Do you have a lot loose connection inside tunner. Need be re solder. Do this and TV will be ready!!.
SOURCE: Channel search for my Phillips PL9125
You should contact to get original remote for that TV.
