I have an LG 50PC5D Plasma, the sound works fine but the picture is very fuzzy and almost seems to be in black and white on all channels. When using the DVD player everything is normal. Any ideas??
SOURCE: 42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
SOURCE: LG RZ42PX11 PICTURE PROBLEM.
I do not know who was helping you before but the problem you are having can be caused by three boards in the tv each by themselves or in combination. Those are the control board with part#6871QCH053G, the Y- board part #6871QYH036D or the Z-board part#6871QZH041B. Without being able to do voltage and signal measurements directly for you, the Z-board is likely the culprit here. But I will tell you that even experienced tv technicians find themselves swapping one or more of the boards until they fix the problem. I am assuming here of course that you have not had problems with your tv before. The part #s I have given you are for the improved boards that LG has assembled to take care of future similar problems and come with their latest training manual for technicians. God bless and good luck.
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
SOURCE: black screen
first try the address board or buffer board.if this
does not repair it,the panel is defective.
