Samsung SP-R4232 42 in. Plasma HDTV Logo
Cliff Hall Posted on Nov 18, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blackout problems I have a Samsung 4232 Plasma TV. Picture blacks out about 5 seconds, but keeps sound. This happens several times a day.
  • Anonymous Feb 20, 2008
    I have the same problem with my Sansung. Did you figured out how to solv this problem?
  • hreshdag Apr 05, 2008
    samsung 40inch 1080 HDTV after a few seconds the screen becomes black and only the audio remains. We shut off, and turn on, and the picture comes back, and after a while does the above agian. Help? A technichian came to the house from BestBuy and couldn't help us. It is a new tv bought in January 2008.
Anonymous
Level 2:
Champion:
  • Expert 217 Answers
  • Posted on Feb 17, 2007
Anonymous
Expert
Level 2:
Champion:
Answers
217
Questions
Helped
84201
Points
262
It could be the LVDS cable that is connected between the logic main board and the main board, sometimes this cable is too short and comes loose from one of the boards, it could also be a sign that the logic main is going out or the panel itself is shorting out
Jay Robles
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 24, 2007
Jay Robles
Contributor
Level 1:
Answers
Questions
0
Helped
1052
Points
How is the logic board?
A
Anonymous
Had this problem to had still som warenty ont the tv so i turned it in for service, They changed the logic board,
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Samsung HP-4252 screen goes black
I have the same problem, and it will get worse. I have read and seen video on youtube, stating that it is capacitors on the power board, that need to be replaced. I watched the tutorial video it seems pretty easy, I am going to try it this weekend. Will update.
A couple of days ago I turned on my brand new (about 6 weeks old) Samsung 50'' plasma pn50b650 I noticed an imperfect picture at the top of the screen. Upon closer inspection, there were about 4-5...
U freeze video games 10-20 mins in video game alot of time.Never pause or freeze any kinds of video image in Plasma tv.It very easy cause to burn in Plasma tv problems alots.
Same problem my tv loses bottom of picture
ONE OF MY CLIENTS HAS THE SAME PROBLEM WITH THE SAME MODEL I REPLACED THE LOWER Y BUFFER BOARD AFTER PLAYING FOR ABOUT TWO DAYS AT THE REPAIRE CENTER THE TV WORKED WELL USUALLY IT TOOK ABOUT TWO HOURES FOR THE PROBLEM TO APPEAR .
Samsung Plasma (HPN4239) when viewing TV something like a black film covers the screen - there is still sound but cannot see picture. Turning off the tv for 10-20 minutes restores the picture. Sometime...
Sounds like the X-Main bd has a problem. It provides the illumination drive signal to the Panel. It can also be the Main bd. Have a trained Samsung tech troubleshoot the set.
1helpful
Periodic tv screen blackouts
The problem is your cable box. I know you said you replaced it, but I work on TV's everyday and, sorry to say this but cable box HDMI outputs have serious issues, like no or intermittent sound and video. I have seen customers exchange their cable boxes 5 and 6 times and still have the problem. Your best bet is to use the component outputs of your cable box, visually you will not see a picture difference between component and HDMI when using a cable box. Your other solution is to get satellite; I have NEVER seen an HDMI issue with a satellite box
Sony Plasma problem - blackouts
What is the model number of your Sony TV?
Red picture
Assuming this is a TV with a picture tube and not plasma or LCD; I'm afraid that your picture tube is dying on you one electron gun at a time. From what you said your green electron gun is almost totally dead and the two remaining blue & green guns aren't far behind. Eventually you'll have no picture at all and I would estimate that to be about 6 more months but whatever the time eventually it will go totally black. These blackout periods will get longer and longer. The only way to fix your problem is a new picture tube but my will probably find it less expensive to just get a brand new TV set.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
