Then it sits a little while and tries to pump again and stops. This goes on for a while then the washer starts to beeb steady. I hit the start/pause button and it the light comes on and flickers above the start/pause button and cant push any other buttons to get it to work. All lights that where on go off when push the start/pause button. The next thing I do is power it off. Is the pump going out or is it something in the electronics or what any help will be greatly appreciated!!!!
SOURCE: Fisher and Paykal GWL 10 US - Stops before rinse
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
SOURCE: MW511 top loader washing machine.
The third and fourth lights from the left indicate a failed motor controller (error code 48) If this is the correct fault code you will have to replace the motor controller. However before that is done all the electrical components which can effect the controller must be checked as well...Best to call a tech...Good luck Nomess
SOURCE: not getting enough water
Hi just read your posting.Now what water temp are you using for you wash cycle?Is it cold , warm or hot?Problem could be your cold water valve not opening enough or your motor controller.If you selected a COLD wash how fast does your cold water come in to the machine?Please reply with additional information on the questions and I can help you rectify this fault.Looking forward to your reply.
