Question about Frigidaire FRT15B3A Top Freezer Refrigerator
Frigidaire Electrolux Not freezing but fridge seems cold
I have a Frigidaire Electrolux model PLHT219TCBO that is 4 years old and it is blowing cool in the freezer and the fridge section seems cold enough but the freezer doesn't get cold enough to freeze.
  • 3 more comments
  • scott48088 Nov 25, 2008
    nothing seems to be cooling now.The evap. isn't iced up,the cond. coils are clean and the fans are running.
  • htinnell Nov 30, 2008
    freezer has water running out and all over the floor, fridge is cold
  • Anonymous Dec 18, 2008
    My fan is blowing in the freezer, and the fridge is cold, but the freezer is not freezing. It is about 5 years old...
  • Bill Newberry
    Bill Newberry May 11, 2010
    The problem you are having is a typical sounding defrost issue.  If you still need help with this let me know.
    Thanks,
    Bill
  • Anonymous Mar 18, 2014
    Whirlpool fridge stopped getting cold and blows the circuit breaker when turned on it is about three years old
    Guru:
  • 93 Answers
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
6ya staff
SOURCE:
Electrolux ETE 4200 SB-R freeze fridge. freezer cold, but fridge wont cool. back of the unit sealed with only compressor (?) visible at bottom. Cant check fans, coils etc. Cheers Gary
That is not a good model number. Is it a top mount freezer or side by side? Generally in electrolux the freezer is what cooks the fridge, if fridge is not cooling, it could be several things causing it.
1. Damper not opening
2. Damper has ice build up
3. The return has ice build up
4. The freezer evap assembly is not defrosting to allow air flow.
5. The evap fan is not turning.
Aug 04, 2018 | Electrolux Refrigerators
Why is the refrigerator section not cooling when the freezer is cold
THE REFRIGERATOR IS BASICALLY A BIG COOLER THE FAN IN THE FREEZER BLOWS THE AIR DOWN INTO THE REFRIGERATOR TO COOL IT SO YOUR FREEZER FAN IS PROBABLY OUT
Jun 11, 2014 | Frigidaire Refrigerators
FRS26R4CB0-Freezer not freezing and Fridge not getting Cool
Hi Candi,
I don't know this model but most friges are the same,
Check on the bottom back, there should be a radiator with a small fan
installed.
If the fan is not working this maybe your problem,
It is not colling the gas.
You also may have a gas leak or the gas compressor is not working
or starting to work because of a faulty capcacitor.
Jan 11, 2014 | Frigidaire FRS26R4C Side by Side...
Fridge freezer is two years old. freezer is working but it is freezing up and the fridge is not working
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Frigidaire Refrigerators
The freezer is COLD..freezes solid. Setting at low. The frige part is not cold and is set at high. Seems everything is going up to the freezer. Unit is just over 1 year old. Drinks are cool but not...
where is the freezer on top,side by side or the bottom.all a fridge does is blow cold air from the freezer to the fridge side that's it,if the fridge is warm there's a problem most likely in the freezer,a plugged drain or when you open the freezer door do you hear the fan blowing,if not you have a bad evap fan motor,also check your warranty it still might be covered.send the model number and i can help you,if you see water under the bottom draws or in the fridge section if the freezer is on top you have a blocked drain in the freezer.let me know what you find and i can help you
Feb 20, 2011 | Magic Chef Refrigerators
Fridge & freezer are cooling on bottom but not
when you open the freezer door do you hear the fan blowing?sounds like the air isn't moving,there's also a damper on the fridge side,the door opens to let the cold air in and then closes,make sure the door is opening,you can take the cover off and put an ice cube on the twirled up metal part to close it and put your hand on it to open it to see if it's working
Mar 21, 2010 | Frigidaire FRS26H5AS Side by Side...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Frigidaire FRT15B3A Top Freezer Refrigerator Logo
1,194 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
