The engine runs good and blades too but the mower is not moving forward or reverse
SOURCE: My Poulan 42-Inch 17.5 hp Briggs and Stratton
OK, so I had the same problem. Would not go into gear forward or in reverse. I took it apart and nothing seemed out of place or broken. I scratched my head for an hour... asked my wife if she had done anything to the machine while I was gone and she replied I only had a tire fixed!!! Bing bulb went off.... She had removed the tire from the shaft and had lost the SQUARE KEY for the drive shaft, one 20 cent square key for the drive shaft and it worked!! TA DAHHH!!
Simple fixes for simple problems.
SOURCE: Poulan Riding Mower will run in neutral, not in forward or revers
you have safty switch on the mower one or more are bad there are three of them
win you put in reverse some mower will cut off this is a safty device on some mower
