Question about Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel Excellence 7.5 kilo Smart drive washing machine . Help fix
  • Anne De Lutiis Apr 07, 2012
    the washer starts to pump water in for about 5 seconds then stops, tries again, etc....then lights 3.5.7 & 8 flash and machine starts beeping. Last week it stopped after the wash cycle but i fixed that by cleaning 2 wires that go into a small box under the control panel. (Could i have put the wires back wrong, have tried either way but no luck) have done several washes since with intermittant faults being these 2 wires ,but the last wash worked fine and now this.. Any help appreciated !!
    Master:
  • Fisher and P... Master
  • 745 Answers
The switch is faulty replace the switch
Posted on Apr 21, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Posted on Dec 16, 2008
Anonymous
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
boxer2
  • 10 Answers
SOURCE: fault 49 smartdrive
Hi have had this problem on phase 5 grey controller, on the controll board near where the valve hot and cold wires are connected you will see a small usually blue resistor value approx 5ohms this is probably open circuit replace it check your water valves before reconnecting I was fortunate enough to have plenty of spare valves so I just replaced both valves as I suspect a faulty one may have damaged resistor machine has been working fine for some time since
Posted on Jul 11, 2010
paulus649
  • 72 Answers
SOURCE: how to unblock fisher and paykel excellence
sounds that you have a jammed or blocked water pump. Just remove the pump and try to unblock it, it can affect the electronic board which may need replacing
Posted on Sep 25, 2010
luisa_sgro
  • 713 Answers
SOURCE: My Fisher and Paykel 5.5
Hi just read your posting.On your model of machine the 3 reasons that the machine does not power up are ,your power point is dead,check with a small appliance, your drain pump is faulty,or the control module is faulty.Did you smell any burning smell near the machine?Is the machine full of water?To check the pump you need a multimeter to check the windings or look under the machine to the front right and you will see a fan.This is your pump.Check with a torch on the pump for corrosion or any burning smell near it.Please reply with additional information on the questions and what the condition of the pump is.Looking forward to your reply.
Posted on Oct 11, 2010
Hi where can I get a instruction manual for my washing machine
go google and type in -- owners manual for ( make and mode ) fisher and paykel washing machine
if it is available there will be a pdf version down load
Oct 26, 2015 | Fisher and Paykel Washing Machines
My fisher & paykel 7.5kg excellence smart drive stopped in spin and now has the 1st 4th and 8th lights on beeping
it is either the control board or the motor wiring, it will need further investigating to determine which of these it is
Oct 09, 2014 | Fisher and Paykel Washing Machines
Our Fisher and Paykel excellence 5.5 smart drive 9, washes fine but when it comes on rinse cycle it wont drain the water and makes a humming sound.
Check your pump with a multimeter for correct reading
230V AC Pump 50Hz 33Ohms +/- 8% @ 20oC
110V AC Pump 60Hz 7Ohms +/- 8% @ 20oC
Also check for blockages that may stop pump from turning.
Disconnect from power & Bail out all the water you can before removing pump.
Jul 07, 2012 | Fisher and Paykel Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
My Fisher & Paykel smart drive excellence 5.5 (New Zealand) has suddenly decided to be strange - after a wash and spin, the long wash and spin lights come on and the machine emits a long continous...
this sounds like a computer error asthe first and last lights is an error code 129 which does not exist if its the first and second to last light then its a sensor fault
Nov 14, 2017 | Fisher and Paykel Fisher & Paykel Washer
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Mar 12, 2008 | Washing Machines
Open Questions:
See all Fisher and Paykel GWL11 Top Load Washer Questions
Fisher and Paykel GWL11 Top Load Washer Logo
42 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
