Had had a problem with out of balance - stripped machine and found small support spring on outer drum had come off. Dismantled drum etc and cleaned it of soap residue. After reassembly, the solenoids both only release for a short time 6 or 8 times before the washer turns off. Do I have an air lock. Any advise appreciated.
SOURCE: fisher & paykel smart drive washing machine leaking water
If your washer is still under warranty, I would call the company and have them send someone down. If the leak is from either the drum itself or a seal then I don't think you could handle it yourself. But, first make absolutely sure that it's not from any hose connection. Tighten all the connections, especially those to the drain pump. And check the pump itself for any leaks.
SOURCE: the solenoids and system wiringare monitored for opens or shorts
The only thing that can cause a saturated vapor canister is over filling the fuel tank.,
SOURCE: no heat from dryer-lighting coil gets red hot, solenoids not open
It just needs new solenoids. Easy fix and I've seen it happen many times. Just get those replaced and you should be up and running again like new. Good luck to you.
SOURCE: 93 ranger not starting, wont turn over.
Take a volt meter and put the red probe of the meter on the engine block and the black probe on the battery Negative terminal. Have somone try to crank the car. If you get a reading of over 1/2 volt, you have a bad ground from the battery to the Engine block. Check the terminals on both ends of this wire.
If the above is OK, Put the volt meter on the battery terminals. (Red to Positive) and try cranking the car. If the voltage falls well below 9.6V your battery is bad. If 9.6 V or more, you may have somthing binding in the engine. When did this car run last?
Good Luck
SOURCE: water drains but won't spin
please rate my suggestion...
