The installation is very easy. You can see a video describing the procedure here:
http://www.desmontalo.com/?p=260
Just, make sure to remove the batteries and discharge the camera flash in advance, to avoid danger of damages for electric shock.
Regards,
SOURCE: card locked
Most SD Memory cards have a little switch on the side to lock them, try switching that to the other position.
SOURCE: Samsung Digimas 301 camera
Get the manual in PDF format here:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=01bb5457f5d9135b41d656864d6de9c6&q=Samsung+DIGIMAX+301
SOURCE: digimax a400 samsung
Problem fix 100% , I opened the camera i had nothing to lose, and took a look inside I tried the camera with out the shell and it work, put the body on the camera back on and everthing works. I did not do anything but open the camera?
SOURCE: Samsung Digimax 420 digital camera
You can download the manual at http://www.retrevo.com
Hope this helps, Scott
SOURCE: View screen is white (blank) with internal cracks
Look fo the switch that has two setting. one of them will say LCD and the other Migt EVF if you have a view through your view finder this is your problem.
