Nokia N900  Smartphone Logo
Anonymous Posted on Apr 08, 2012
Need app for use front camera n900
How use front camera
  • Anonymous Apr 14, 2012
    i have nokia n 900 mobile phone.n900 have 2 camera one up one dwon.if i m open the dwon lens cover dwon side camera open otometic. but my problem, i m how to open my uper side that mens front camera.its need some driver or any softwer? pls give me sollotion.also give 1 skype app its comfortable for video calling.thanks fixia.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 29, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
161
Points
The nokia n900 can only for now use the front camera with skype call.maybe later it has an app for normal front camera.
How to use the front camera of nokia n900
I HAVE FOUND A SOLUTION ...YOU HAVE TO DOWNLOAD AN APP CALLED 'MIRRORS' BEFORE YOU CAN USE THE FRONT CAMERA BUT ALL THE FORUMS I HAVE BEEN ON TO FIND OUT SAYS IT DOES NOT TAKE VERY GOOD PICTURES...LET ME KNOW IF THIS WORKS
1helpful
N900 have front camera or not
i want restore my nokia n900 mobile.my IMEI no is 356938034771924 but system asking pin number also.How can i get that pin number
2helpful
I want to refreash my nokia n900
Try this its found under settings, "Clear Data" Option next to "Restore Original Settings". Does not remove apps but does remove all the data. Click settings and then there is the dropdown menu when you touch "Settings" at the top of the screen. Used to be just a "Restore Original Settins" which only did settings not data. If thats not working for you try this link, though it's a little complicated. http://theunlockr.com/2010/04/02/how-to-hard-reset-your-nokia-n900-get-it-back-to-out-of-box-state/ Hope this helps ;)
1helpful
How to clean rootfs in nokia n900 ?
use purge for installed apps. And dpkg -l ' grep ^rc (this command will show you a list of apps configuration files still left in the system from uninstalled app)
dpkg --purge <appname> (This will remove it)
Performance Chip
N900 camera showing black screen
Please switch on the camera, if you have enough charge on the camera.. or else charge it.. Even after switching on the camera, if it is black, then screen might got have damaged.. Service it if you have warranty..
4helpful
2answers
How to use secondary camera in N900
Hi punith3,
You can download an app called Mirror which activates the Nokia N900 front camera.
You can get it at:
http://maemo.org/downloads/product/Maemo5/mirror/
Best regards,
CellPhBuddy
Can't find the secondary camera icon in the application manager/phone?
Hi there!
There is no specific icon for the secondary camera - the secondary camera is really just for Skype video calling.
There is an app called "mirror" which uses the secondary camera and displays the real-time image on the phone (image clarity is not very good though due to the low resolution camera). You can download it from http://maemo.org/downloads/product/Maemo5/mirror/.
The nokia n900 keeps rebooting continuously..cant access any menus..no apps are loaded before the reboot happens again..
Try this:
Remove any memory card and sim card.
Check that the back cover is fitted correctly and that the camera shutter is closed.
Try to boot with N900 not connected to charger and see how far it gets.
If it helps, please rate. If it doesn't, write again.
Thank you
Jan 22, 2011 • Cell Phones
1helpful
Secondary-front camera of n900 not working
Hello I am Afer Ibrahimov From Azerbaijan. I have bought a new Nokia N900 from USA but it is made in KOREA. I have some problems with my Cellphone. My N900 secondary camera and radio for Asia Countries (AZERBIAJN) does not work.
What Should I do?
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
