If you are facing the problem with windows update then perform the following tasks before updating:::
>> Scan your computer with an antivirus >> Apply De-fragmentation on your system>> Delete all temporary files>> Run disc clean up>> Fix registry errors.>> Use a system utility tool like Reginout for an instant fix.
Using my experience to get Windows product key.
Try it: www.acyberkey.com
After i used, my windows work great,hope can help you
SOURCE: when I got my Packard Bell easynote I had to
yups friend in google just type this product no and ask for that cd after that put hyphen( - ) and type torrent you will definitely get that ....
SOURCE: windows 7 Audio Not working
I had the same problem i was under the impression I had a realtek audio system in my laptop but it turned out to be Conexant High Def sd2 i found it by accident but on the HP website ..so try your comps manufacturer web site and and search the driver section and u might get lucky, also right click on the driver select trouble shoot and click troubleshoot then select the program worked in an earlier version , then select your old OS (XP) then click start program and it should start to install, when it does and if it works select save settings for this device within the same trouble shoot window, u will have to do a lot of this seeing as how its an RC and not fully equipped with all drivers
Testimonial: "thank you so much the sudio should b working after my reboot"
