My HP TX1320US not powering up .. seems dead.. not booting up at all..
Two days before my laptop died there was sudden freeze.. everything froze for about 2 minutes.. ithappened couple of times.. at time freeze was for 30 sec and at timesit was for 5 minutes.. I saw that CPU usage hit 100%
I restarted the machine couple of time.. it started but the same problem..
then suddenly it refused to start.. with power on and battery
Whenever I slide the power on button.. there is less than a 1 second flash of the units LEDs and it powers off.
I disconnected the battery, power and left the machine for about 5hrs.. tried starting again but no success..I have tried with andwithout wall power. I have tried it with wall power and no batteryobtaining the same results. The power adapter is fine as it can powermy other laptop pretty well.
Interestingly warranty on my machine expired during last week of October 2008.
Interestingly, almost everyone is experiencing this kind of problem with HPTX1000 series. Most interesting part is that this happened with in amonth after their warranty expired.
The problem is in the GPU this defective chp is verheating and causing the WLANt fail and then it gets the solder joints loose on the board causng no video. It is a rather easy fix if yu are ok with removing your own motherboard. If interested I am willing to do the fix for anyone that has one of these machines. I have one and completed the fix on mine and 4 other machines. If interested email me at [email protected] thanks and good luck.
I have tx 1320 and have the same problem like everybody hp said pay $390.00 for new motherboard. Had my tx 1320 less then 2yrs
I call the hp techs 4 time in less then 2yrs.
I have seen where the memory can become loose and you need to re-seat the RAM.
G'luck
my laptop simply stopped booting up. blinks once, then shuts off. ii need help
I've been facing the same issue, besides when i get the pc on, it doesn't recognize any wireless signal.
MY LAP MAKE THE SAME, PLEASE HELP
i have re-seated my RAM - still won't boot. isn't there an internal recovery? HELP
DOES NOT START, I HAD A TECHNICIAN OPEN IT YESTERDAY, IT IS THE MOTHERBOARD. JUST ONE MONTH AFTER WARRANTY EXPIRED!!
DO YOU KNOW WHERE CAN I BUY THE MOTHERBOARD...(WITH HP IT IS ALMOST 800 DLLS)
Exact same problem here. Reseated RAM, issues still there.
comp does not start or boot at all
Yes, Note does not boot. I have resetlled tht RAM twice and still continues.
Any help?
The situations is that the laptop will not boot up, lights come on, fans start spinning then screen stays blank. My warranty expired on 12/2008
As soon as i start my computer , i can hear the fans going on and all the lights turn ON on the screen also the speaker, mute audio and wireless lights will turns on, and will remain on for ever, the computer won't boot. I tried booting the laptop i different ways like without hard drive, i even swaped the memory cards but same result.
I HAVE THE SAME PROBLEM CAN SOMEBODY HELPS PLEASE
It's the motherboard from what i've read on other forums. we are all screwed and hp wont recall it.
My computer TX1320US is dead and since I got it always have problems, never work well. I took my computer to repair and in the place I went they told me all these computers have an extension of warranty, Does anybody knows if this is true? Because the only thing I have found is that a lot of people is in the same situation and HP is not responding for it if your warranty already expiry.
