To Unlock SAMSUNG GALAXY S I9000 Phone use the Unlock code...Buy the Unlock code from here Prounlocking.com/samsung/rs8wp8/
and Unlock it from network lock.Then use with any GSM Network Sim card.
SOURCE: samsung galaxy android unlock..cannot unlock my
Hi, I have a couple of idea for you to try.
1) Log in to your google account on your pc, the same account you registered for your phone
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as , [email protected]. Now this google id on the top right corner of the page would be displayed as [email protected]
3) Type in the google id, thats visible on the right hand top corner of your page (like [email protected]) into your galaxy s handset locked page, and type in the password.
TADA AND YOUR ON TO THE NEW SCREEN TELLING YOU TO PUT IN ANOTHER PATTERN.
or theres this one:
Take out the battery, the sim card, and the SD card leave the phone for 2 to 3 hours like that.. Put everything back in and boot up the phone.. This should work.
You could try this instead of waiting 3 hours, just remove battery and press power on switch for 20 seconds but this may not work.
or if you've tried everything, the only other way would be to take it to a Samsung mobile phone shop.
or do a factory reset:
THIS WILL ERASE ALL YOUR DATA THOUGH
Go into recovery mode - vol up & home & power. Once in the menu, select factory reset.It may take you a couple of attempts to get to the recovery mode but it does work, just keep trying.
Regards
Mike
SOURCE: Problem with the Samsung Galaxy
open music player and find your song
hold you finger on the song for a few seconds and select
"set as"then make your choice
SOURCE: have a Samsung Galaxy S
CONTACT O2 FOR THEM TO RESET YOUR INTERNET CONECTION. THEY SEND A SIGNAL TO THE PHONE TO USE ON THERE NETWORK . IT ONLY TAKES A FEW SECONDS.THEY WILL ASK YOU FOR THE MAKE AND MODEL OF PHONE AND YOUR NEW PHONE NUMBER.HAVE THESE READY.
SOURCE: computer wont read samsung galaxy
the computer is not the problem, the problem is the phone. you must make sure that the phone is set to enable USB connections, usually when you connect the phone the phone will display a pop-up asking you what you want to do, additionally you could go to the settings option and set the default action for when the USB is connected. what you probably want to do is data mode, which lets the phone act like a USB stick.
SOURCE: Samsung Galaxy S GTI9000 Smartphone Problems &
there is quiet alot about that phone here on android forums. just go there for problems and solutions.
