Set program switch on pump comes on will not start the program the pump keeps running thats all
SOURCE: Zanussi WJD1257W Washer/Dryer
if computer is broken that is your timer dial not worth fixing sometimes as much as a new washer but it could be your interlock you can test this by closing door set machine to a programme hit the front of your washer to the right of the door as you look at it if not take lid of make sure power is off look down inside the front of your machine were your door seal is attached to the outer drum were u hit the washer on the inside will be your interlock switch replace that before paying out for a timer m8 more than likely that is the problem
SOURCE: Zanussi
The drain filter is clogged (E20)
online manual
http://www.serviceforce.co.uk/pdfs/U21039.pdf
SOURCE: zanussi washer just keeps on trying to drain
this is the electronics on the machine reacting to a fault .the electronic has detected an electrical component fault .for example a motor gone short circuit you can only find out what by testing the components with a suitable test meter or by acessing the machines own diagnostic facility and retrieving the error code .if cant test with a meter you need the manufacturers service engineer
SOURCE: how to fit a door seal on zanussi washer dryer WDT 1085
Follow these steps to replace your door
seal:
For all Free appliance repair videos visit our VIDEO
TUTORIALS
Disconnect all power to the machine first!!
1 Locate the
outer clamp band securing the seal to the door rim on the washing machine and
examine it carefully for holes or tears. Many can be prised off with a
flat-bladed screwdriver they have a spring system holding them, but some have a
tensioning arrangement that has to be loosened.
2 After
removing the outer
clamp band, locate the inner one securing the seal to the drum and
establish how this is secured. It may be necessary to loosen a clip, or you may
be able to prise the band off with a flat-bladed screwdriver. Some are like
very large Jubilee clips that you have to undo usually from the top.
3 Once the
clamp bands have been removed, use both hands to pull the seal away from the
inner drum rim. Some machines have a water spout holes that will have to be lined
up. Others have a drain holes.
4 Rubbing a
drop of washing up liquid into the groove on the door
seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing
machine door seal should be fitted by locating the drain holes at the bottom
of the seal first then push it on with both hands working opposite directions
towards the top. This is quite hard if you have never done it before.
6 refit the
inner band remembering this must be tensioned correctly for it to be water
tight.
7 now fit the
outer band and the test the machine for any leaks,
All washing machine spares featured in this article are
available at apart4u with more video
help in our tutorial
section.
Information provided is a guide only. aPart4u accepts no liability for any
problems occurring whilst attempting any advice shown. If in any doubt about
fixing your appliance, always contact a qualified repairer.
SOURCE: i have a zanussi washer dryer zwd12270w and the
I would first check your line voltage to make sure its correct. Next I would try unplugging it for 10 minutes. If thats doesnt work I would then look at replacing the control board.
