We have tried every CC option on the TV - both manually and using the remote. It says the captions are off - but they still keep showing up. This is maddening! Please help!
SOURCE: How do I enable closed
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
SOURCE: Zenith Concierge hotel tv wont work with my xbox 360
There may be a door in the front of the ste that is locked. You could take off the back and see if there are any circuit boards attached to the front of the ste and then that would show you where the door would be. Sometimes they losck the door with tabs on the inside and has to be pryed off.
SOURCE: zenith 27 in TV
I am looking for a couple of parts for my zenith tv model # A27A11D.
fuse-1360011423A
knob array-04610578
SOURCE: Captions only on certain channels?
Closed captioning isn't broadcast on every channel and program, so the information may not be present. Since captions are displayed on other channels, you know the set is working properly. If you are on a cable system you can try asking their customer service people if they know anything. But the TV is fine.
SOURCE: ho w do i turn off the closed captions theres
dose the cap come up if vol. up down or channel up or down buttom sholud let you change setting
