Samsung HLR5667W 56" Rear Projection HDTV Logo
Jerry Layde Posted on Apr 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung TV will come on, sound comes on for a few seconds and stops. The picture changes sizes 3 times and the unit shuts off
When turned on. The sound comes on for a few seconds then goes off. The picture is good but after 10 to 15 seconds the set clicks and the picture resizes, sound comes back on for a few seconds and goes off again. This runs a cycle 3 to 4 times ant the TV shuts off. The lights on the front are in the STANDBY/HEAT. The Color Wheel, Fan2 and Lamp have all been replaced.
  • 1 more comment
  • Jerry Layde Apr 11, 2012
    I need further input? What is dmd? I have made sure the problem was not the input mode. Tried VCR, DVD and PC. All have the same results. Have unplugged and reset with at least 3 minutes in the no power mode at all. When plugged into the AC outlet... let stand for at least 1 minute before hitting the power button.
  • Anonymous Apr 11, 2012
    The DMD is the metal box with a lot of round holes punched in it that the two cables from the color wheel plug into---it communicates with light engine to and from main chassis---if bad not worth fixing--better to replace entire engine.
    One other stupid suggestion--cannot hurt---blow the set clear of all dirt/dust especially the three fans(lamp, dmd fan, and another.
  • Jerry Layde May 20, 2012
    I have checked the flat ribbon cable from the color wheel, it is correctly installed. When I replaced the lamp, the TV worked correctly for a week. Then the picture sizing and cycling started.
Anonymous
Level 3:
Top Expert:
  • Samsung Master 14,553 Answers
  • Posted on Apr 10, 2012
Anonymous
Samsung Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715319
Points
48227
Suspect number one is not fan, lamp or Color wheel--optical light engine with dmd is.
    An after thought= if this started after color wheel was replaced--look at the two cables from it to the DMD---the flat ribbon cable only has contacts on one side and can be inserted backwards........not in most instructions for replacing the wheel.
    Contacts on that cable usually face the rear of the set.
  • Anonymous May 20, 2012
    based on what you have told me I have no further suggestions short of being there.
3 Related Answers
Anonymous
  • 304 Answers
  • Posted on Jul 16, 2009
SOURCE: samsung model # HLP5063WX/XAA 3 lights blinking
It can be the Lamp Ballast as well as the Color Wheel.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Aug 28, 2009
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Anonymous
  • 556 Answers
  • Posted on Oct 20, 2009
SOURCE: Samsung HLR5067W replaced color wheel, LAMP light blinks
according to samsung this is indeed the problem.
Testimonial: "Excellent expert advice. Confirmed what I believed to be the problem and it was. Very knowledgable"
2answers
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
2helpful
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
2answers
No picture few seconds sound coming
Sounds like you got a bad logic board inside this unit with defuncted capcitors looks like salvation army time..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
TV turns on and then, after a few seconds, picture changes to "double vision".
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
3helpful
4answers
Camera shuts off after a few seconds
i had that problem with another camera i toggled with the lens it went in and works like a charm. Dont be to gentile it will go in
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Won't turn on
those tvs will try 3 times before completely shutting down. you can try and take the back off and check CP150 it is a large capactior located near the middle of the board on the left hand side(looking from back) if it looks and feels like the top is vented or puffed out then that could be the problem. if not i suggest having a qualified service tech take a look because there are too many things that could be the root cause.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
