Toner ended problem for DCP 7055
Toner ended how fix
Have to do the key sequence fairly quickly or it defaults back to the "COVER IS OPEN" message.
1. Open the front door to access the toner
2. Press the "Clear" button.
3. Press the "Start" button.
(When you press START the screen should clear.)
4. Press the "?" or "Down Arrow" button.
5. Press the "?" or "Up Arrow" button.
(When you press the down arrow an 'E0? should appear, which will change to '00? when you press the up arrow)
6. Press the "OK" button.
(When it say s 'ACCEPTED')
7. Close the front door.
SOURCE: http://blog.tonerparts.com/how-to-reset-for-brother-dcp-7065dn-7070dw-7055/
SOURCE: how to get ride of Toner life end message
You could try resetting the toner cartridge settings. OPen the machines front door where you would replace the cartridges. On the top panel you will see a "clear/back" button. Press it and on the display you will see a reset menu come up. Arrow to each one and hit the OK button. Press "1" to reset. Once you have gone through all close the front door of the machine and press stop to bring the display back to normal.
Hope this helps.
SOURCE: Brother 4070 Printer will not recognize new toner cartridge
Hi
Just cover the eyes (on both sides) that you can see in the bottom of the machine after removing the imaging cartrige with a small piece of electrical tape.
With printer switched on push the switch which is located inside the upper left side of printer (it is a small white switch) and then release it.
Also try resetting the gear, take the cartridge out. On the gear side take off 2 screws, the black gear on top right side, with a small spring underneath. Just take it off and reset it (rotate clockwise) so it is not at the stopping point.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
SOURCE: Brother 5240 laser printer changed toner still wont work.
This works on several different Brother Printers to get rid of toner/drum empty errors:
1. Open the front cover and leave open while completing the following
steps.
2. Turn the printer off.
3. Hold the 'go' button while
turning the printer on. All panel lights should be on.
4. Release the
'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7.
Press the 'go' button 5 times.
8. The toner light should be off.
9.
The paper light should be on or flashing [doesn't happen on all].
10. Close cover. The ready
light should be the only light on.
SOURCE: brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
