KENMORE HE2T WASHING MACHINE
What wire would be affected with a error code of f-25 for this kenmore HE2t washing machine?
  • Anonymous Mar 28, 2014
    sign sb
  • 5,911 Answers
"F25" is a tachometer error. If the control unit is unable to detect the proper motor speed, the machine will shut down. You can attempt to unplug the washer for at least 30 minutes to reset the computer. Sometimes this is all that is required to correct momentary glitches. If the error reappears, the manufacturer recommends the following:
1. Check the wiring harness between the Central Control Unit, Motor Control Unit and Drive Motor to ensure they are all connected properly and not broken or loose. This would be connections L2 and N1 at the MCU and connector MS2 pins 1 and 2 at the CCU. (There is a wiring diagram inside the washer behind the lower kick panel).
2. Verify the Drive Motor is turning and the motor windings are good. Resistance checks at the drive motor connector acros Pins 1 to 2, 2 to 3, and 1 to 3 should all read about 6 ohms.
I hope this helps you.
PS I believe the tachometer is a physically attached to the drive motor.
Posted on Nov 12, 2008
6ya staff
SOURCE:
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
My Kenmore HE2t washer is stopping about 8 minutes into the cycle (any wash cycle)..completely turns off. I can run rinse and spin then and it completes the cycle. No error codes when it turns off. W
htc sensor isnt working i would recon
perhaps the element isnt getting power
did it trip your circuit breaker
some times the htc fails
all you get is machine stop because the heater is not detected
if it spins rinses and empties in a timely manner
then all thats left is the heater system
Jan 09, 2015 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
I have a Kenmore HE2t i keep getting error f21 i cleaned the trap and it still does it
You may have to unplug it for about 15 minutes and try again. I had a similar problem and this helped.
Mar 19, 2014 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
Kenmore he2t F25 error. Trying to ohm test the MCU. Are you supposed to stick the leads of the multimeter into the holes of the white connector where the wires go in, or to the wires themselves? They're...
Hello!
Most likely, error F 25 means that the aquasensor, the turbidity sensor of water, has failed.
Possible reasons of this error:
1) Perhaps there was a clog in the system of draining the water. Dirty water does not merge and because of this the sensor shows muddy water. It is necessary to clean the drain filter;
2) Lime or scale on the turbidity sensor. Always use high-quality washing powders or add descaling agent
3) Dirty water got into the plumbing. Drain all the water and run the wash program in hot water. The washing machine should be empty.
May 15, 2017 | Kenmore HE2t 3.7 cu. ft. Front Load...
I have a model #110.47561601, Kenmore HE2t Front load washer Type 832. I am getting a code of F-24, when I try to start the cylce. What is the problem that prompts a F-24?
Hello
F-24 is a water temp snsor error.Try running the machine in spin and drain.Once empty unplug machine for 3 min.Then try load of wash again.This time use cold water until error clears.
Aug 27, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
Sep 23, 2009 | Kenmore Washing Machines
Kenmore front load HE2 plus
I have a F01 error message on my Kenmore He2t washer. I tried to add clothes to a wash and restart and continue to get the message. Please help
Jun 14, 2008 | Kenmore 46462 Front Load Washer
Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Dec 29, 2007 | Washing Machines
Washing Machines Logo
388 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
