SOURCE: C:progra~1\mywebs~1\bar\2.bin\m3plugin.dll
Try this, click the start menu, select "run". Type in msconfig ....
Go to the startup tab... Next look for the same path there, when you find it, un check it, click apply, ok, restart now
All done
Have a nice day!
SOURCE: c\PROGRA~1\MYWEBS`1\bar\.bin\M3PLUGIN.DLL
Hey dear its a virus, luckily your antivirus has already removed it from your pc. one trace is remains in registry which will try to load it on startup.
Ok, do the following step and get rid of it.
Open Run , type regedit and press enter
Go to
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon
and check for the key Shell, the value of this must be Explorer.exe . if you can see some other after that like Explorer.exe C:\PROGRA~1\MYWEBS~1\bar\2.bin... , then remove the second file from the value, means it must only Explorer.exe
Ok, then check for the key Userinit. the value must be C:\WINDOWS\system32\userinit.exe, (including the comma) . If after that some thing is there , then delete it.
Ok thats all. restart your system
SOURCE: Error loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll
Mywebsearch is a spyware program. Run a spyware scan right away. "MYWEBS" is an indicator you are infected.
SOURCE: C:\PROGRA~1\MYWEBS~1\bar\2.bin\M3PLUGIN.DLL
Is every program running fine? It is a registry file - in other word a file that is the basis for all programs. If every program is running fine, you can delete by start>run>and type regedit or if in Vista start>and type regedit. Use the path in the error (C:\PROGRA~1\MYWEBS~1\bar\2.bin\M3PLUGIN.DLL) to find the file and delete it.
SOURCE: Error \PROGRA~MYWEBS~1\bar\6.bin\M3PLUGIN.DLL
Maybe Registry Easy can help fix this .dll error.
Registry Easy is an excellent Windows Registry Cleaner that helps you scan your PC, safely clean the errors & invalid entries cause system slow, freezing and crashing, and repair registry problems to speedup your computer performances. It is easy to use.
http://www.keep-pc-clean.com/registry-easy-cleaner.html
