I had to reinstall windows on the computer and i cant get it on line it acts like the drivers are not there to operate the ethernet card nor will the wireless turn on
Sounds like the drivers for the network card are not present...
Grab a flash drive and the model number of your PC. Go to another internet connected computer and download the ethernet (and wireless if that's what you need) drivers frome here to the flash drive. Go back to your PC and install from the flash drive.
SOURCE: I have Gateway MX6214 and
I'm not sure what happened but we got disconnected somehow. What you want to do, seeing as you are using another laptop, is download the software from Gateway and save it onto a cd-rom. Insert the cd rom into the gateway, open the driver and install the driver onto the laptop. This should work. If it doesn't, let me know!
SOURCE: Missing drivers for "other devices"
Go to Control Panel - System - Device Manager and right-click on each of the hardware components where you need drivers. There will be a description of each item, so then you can download the drivers. Good luck
SOURCE: no drivers
I have several Driver cd's for Many Gateway laptops. I may make you a copy for a small fee. I even can get you a OEM cd/rom if you tell me if you are using home edition or pro edition? Contact me.
JMC
SOURCE: drivers for other device - gateway laptop
You will find the drivers needed from this URL: http://www.acer.co.uk/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3734&sp=page15e&ctx2.c2att1=17&miu10ekcond13.attN2B2F2EEF=3734&CountryISOCtxParam=UK&ctx1.att21k=1&CRC=3713735360
If this has helped you then please rate me!
SOURCE: gateway 450rog notebook cleaned hard drive and
I took a look out on Gateway's download site and found the usual drivers for your box.
gateway's download site
In particular here is the url to the network driver I think you are looking for
network driver
Hopefully you can use a friends pc to connect to this web site, download the driver onto a usb stick, and then take that to your laptop and install the driver.
good-luck.
