Cell Phones Logo
A
Anonymous Posted on Jan 17, 2018
I had a locked telus phone which I got unlocked. I use a bell chip in it. But now I wanted to go to koodo so I got a new chip with them and put it in it is saying phone not allowed MM6? what does this mean? do you think it is because telus and koodo are the same company and the phone was just banned?
UnlockNinja
Level 3:
Master:
  • RIM Master 462 Answers
  • Posted on Jan 19, 2018
UnlockNinja
RIM Master
Level 3:
Master:
Answers
462
Questions
0
Helped
215820
Points
2284
This Mean your phone is NCK locked. So you need a Network unlock code so that you can use this for any network.
here is the process to get the unlock code
Go to below link
Unlock Your Cellphone Use Any Network in The World
Select As
Brand Name:-
Model No or Name:-
Country from The Phone Purchased:-
Network on which The Phone Is Locked:-
IMEI No:-
E-Mail ID
Place a Request for unlock code. this will delivered to your mail id with least possible time (Depends on the network)
You need to follow the below steps to use the unlock code
1) Insert a non compatible SIM card to your locked Cell Phone,
2) Phone will prompt for Unlock Code (NCK Code),
3) Enter the Unlock Code you received.
Phone will be unlocked for any network
I had a locked telus phone which I got unlocked. I - cover page unlock ninja-zfzwxcyuxjlckxsyo3ojiz2q-4-0_0.jpg
5 Related Answers
Anonymous
  • 38 Answers
  • Posted on Jan 06, 2008
SOURCE: unlock cdma verizon for to work with telus
Did you try the six Zeros? if you could post or email me the ESN Hex. i might be able to get the SPC code for it. so you could follow telus instruction on programming the phone with them.
Verizon phones could be unlocked via keypad codes. code generators, and via software. Also please post the phone brand and model.
Thanks
Anonymous
  • Posted on Oct 11, 2008
SOURCE: how to unlock a lg8500(telus)
with the phone turned on and the keypad showing hit the ok button then push 0 a service code entry promt will come up enter 000000 its your baby from there
Anonymous
  • 75 Answers
  • Posted on Dec 22, 2009
SOURCE: Phone is not allowed MM6 in Blackberry bold 9000
Your phone has been blacklisted from whatever carrier you're trying to use. The solution is to unlock (go to www.unlockbb.com if it's not unlocked already) and try another carrier.
fixberry
  • 437 Answers
  • Posted on Feb 17, 2010
SOURCE: blackberry curve 8520 - phone not allowed mm6
Enter http://blackberrymep.com and follow instructions there, it's the best solution for unlocking your blackberry, it's easy, fast, cheap i have tried many other methods, but i found it the best.
Anonymous
  • 142 Answers
  • Posted on May 20, 2010
SOURCE: Not Allowed - Legal unlock code
The phone isn't faulty, the 'Not Allowed' error simply indicates that the phone has been subjected to it's maximum allowed number of code entry attempts. There is a possible solution to this at the link I have supplied below.
Unlocks
HI could somebody please help me unblock my IMEI number -358354050069128 its a nokia lumina 1020 on telstra in australia ,
Unlock Telstra Australia Nokia Lumia 1020
to use any where in the world with any supported service provider likeAT&T, Straight talk, T-mobile, Vodafone, Personal, Claro, O2, Digicel, Telcel, Orange, Telenor, Optus, Tele2, MTN Rogers, Fido, Chatr, Bell, Virgin, Sasktel, MTS, PC telecom, Tbaytel, Telus, Koodo
You can request the code by submitting your imei
@http://www.WorldGSMCodes.com
Your phone will also keep working with your current lock to service provider.
Take Your Telstra Australia Nokia Lumia 1020 with you on vacations and use the local service provider sim card in your phone and save roaming fees.
Telstra Australia Nokia Lumia 1020 Unlocking Instructions
1: Turn on phone with Not Accepted SIM card.
2: A menu will pop up to Insert the code.
3: Insert the provided code and press OK
4: Device is now unlocked.
After Unlocking Telstra Australia Nokia Lumia 1020 will work with
Also any where in the world with any Supported Carrier
*Supported carriers can vary based on your locked to carrier and your region, please confirm with your service provider, before placing order
Your phone will be permanently Unlocked,it will not erase your contacts or any data from your phone.
Is there a free unlock code anywhere. I do mean free only. phone locked to bell and want to go to koodo
Hi if you want to unlock your phone from bell network provider to freely use it with kodoo or any other GSM sim then code is the best solution to unlock it ..If you are having older mobile model then free codes are available to unlock those model phones .You can get the code from online providers like Unlocking4Free.com here they are generating network unlock code for some older mobile models at free of cost ....
Oct 15, 2014 • Cell Phones
How to activate my telus sim card
HI if you want to activate or use your telus sim in your phone then you must first check that whether your phone is locked or unlocked one .If it is unlocked one then it will freely accept telus sim else if it is locked to some other network provider then it wont accept telus sim until you unlock it .You can easily unlock your phone using sites like UnBBLock.com they are rendering unlock code for all blackberry mobile models at reliable cost .Else if you want to unlock some other mobile model then visit sites like Unlock-Zone.com they are rendering unlock code for all mobile models ,After unlocking your phone you can freely use it with any GSM sim ...
Jul 05, 2014 • Cell Phones
Why droid razor can't receive picture messages
The simple answer is your settings are wrong, you can go to your carrier to fix it or a local repair shop.
The setting that is likely needed to be added or changed is called "apn" which is access point network.
If you feel comfortable with changing things in your phone; Go to settings > more.. > apn (if on screen) or mobile network > apn > menu button > Add or New > The next part will depend on the carrier you are on. The link is an example of Canadian carriers apn settings. Android Coliseum Rogers Telus Bell Fido Virgin Koodo APN List
3helpful
2answers
How to get my cell phone to work on another network
Depending on the model of the phone and how old it is really makes the difference if you can in fact use your phone on other networks. If you have a phone that was made after Feb 2010 then you can use it on any of the major cellular providers (Bell, Telus, Fido, Wind, Rogers, Koodo) Rogers and Fido operate on GSM technology (Global System Mobile) Where (as of Feb 2010 ) Bell, Telus and Koodo use the HSPA Technology (High Speed Packet Access) and Wind Mobile uses AWS (Advanced Wireless Services).
So to make this less confusing now every major cellular provider in Canada uses SIM cards. So all you would need to do is take your phone to the local mall and get it unlocked (usually cost anywhere from $20 to $50) and then you can use it on every network with the exception of Wind which only is compatible with some devices.
Lastly before you go ahead and get your phone unlocked make sure it is compatible with the provider you wish to go with. You can either go online and search "IMEI Phone Compatibility" and check yourself or take it to any one of the Cellular providers and they will check for you.
I hope this answers your question
cheers
-Mike
Mar 09, 2013 • Cell Phones
Looking for the unlock code for samsung a667 evergreen
Hi, it is possible to remove the network lock of Samsung a667 Evergreen
with services at fastgsm.com so give it a try, I can recommend it.
2answers
My phone won't connect to the telus network. Ive put the sim card in properly too.
hi your nokia mobile is network locked so only it dint accept other network sim .to solve this codes are the best solution .to purchase codes visit theunlockarena here they ask the network name to which your mobile is locked then the imei number of your mobile .finally they will send you codes to unlock your mobile .once it is unlocked then it will be free to all network sim.
1helpful
2answers
What is the code to unlock INQ chat 3G from Telus?
Go to the link http://www.mobileincanada.com/How-To-Unlock-Telus-Koodo-INQ-Chat MobileInCanada has the unlock code for the INQ Chat 3G from Telus
Dec 15, 2010 • Cell Phones
3answers
Blackberry 8830 CDMA from telus to bell
there is no way but u can sell the phone
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
