Computer came equipped with Vista Home Basic. TouchPad was set to disable when I installed a mouse. After upgrading to Win7, I no longer have that functionality. I.e., TouchPad stays on with Mouse also installed. With my big hands, I'm constantly bumping the touchpad and moving the cursor unexpectedly. The "hidden icons" part of my toolbar shows a "Synaptics Pointing Device". A Synaptics PS/2 TouchPad is listed, and properties say it is working properly. The "Disable" button is greyed-out, however. Will appreciate suggestions.
SOURCE: touchpad/mouse problem
Same thing here, I can not find out how to diable the touch paid. I spent an hour chatting on-line with Dell Tech support and they did nothing to help!! I am starting to think it can not be done on this machine. Please someone tell use how to do this?
SOURCE: Cannot disable touchpad.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=EFB3FA8537BFDD4DE030030ABD620900&doclang=en
This link is the answer to you problems.
Good luck my friend.
SOURCE: must disable touchpad
Is the problem being caused by your palm hitting the surface of the touchpad? This happens with many people. There is a setting for the touchpad which will let you set how sensitive the touchpad is, thereby eliminating your problem.
SOURCE: How do I disable the touchpad?
Try disabling the touch pad in the device manager. If that don't work unplug it from the motherboard. You will have to take the bezel and the keyboard off to unplug the touch pad.
SOURCE: I cannot disable my Dell Inspiron 1545
Hi , please follow this hints:
- While your screen on idle, click windows start button, move cursor up the start menu and pause
over settings line
- You should found pop up menu click control pane to open control panel window
- find the mouse then double click it
- Found the option you are looking for there
Regards
