Toshiba SD-140E DVD Player Logo
Rajesh Tanna Posted on Nov 11, 2006
No Picture. Sound O.K.
The sound on this DVD Player is O.K. but it doesn't produce any picture. What could be the problem? Does anyone have a service manual for this one?
  • jennangel82 Feb 07, 2008
    The dvd player is connected, there's sound, but no picture no matter what i try. The apex tv has video 1, 2, and 3. I've tried hooking in to each of these. Also have an svideo cord connected to both the dvd and the tv. No matter what wires I try or channel I receive the same sound, no pic.
A
Anonymous
Hold down the stop button and that should fix it I'm sure it will work
A
Anonymous
Yuo must have press the progressive scan button hold down the play button for a few minutes and it should come back to normal
Samsung hdtv, I have sound but no picture. This is an older tv, I have had it for about 6 years.
Have you try watching using a DVD player on your t.v if doesn't try watch on it using a DVD player but if still it doesn't have a picture but only sound perhaps there is a problem with your HDTV.
Toshiba modelsd v392su dvd sound and picure perfect vcr SOUND GREAT NO PICTURE and I have done all that is needed to review all inputs to make sure thye are in and i know they are in the proper...
DVD produces a great picture with sound - but the VCR is not producing a picture? is it snowy? or a black screen? if it is a black screen, the video output from the VCR is possibly faulty, this is not economical to repair. If it is just snow, and there is slight evidence of a playback picture from your tapes, try cleaning the video heads with a head cleaning cassette (available from eBay and electronics stores as a discontinued stock item).
Since Hi-Fi VCRs have the left and right stereo track on their head drums, and this drum becomes worn or dirty, the sound deteriorates along with the picture - mono sound usually with lots of snow.
This is a combo unit - it has a VCR/DVD common output section on the rear - allowing DVD and VCR pictures to be viewed when the respective drive is selected. When you checked your input connection, did you check the rear of the unit? you may have connected 'DVD priority out' instead of the VCR/DVD common out. If you did connect the common out, and still have no VCR picture, try the head cleaning suggestion as above. If that fails, consider replacing the unit as a last resort.
I am offering this suggestion 'gratis' - free of charge.
No sound
check in the menu for sound or try a dvd player is there sound?
Disc spins but no picture or sound
I bought a new one. Thanks anyway.
Lights up screen, has sound, but no picture on the units screen!
has good sound--but no picture. the hookup cables are correctly installed
3helpful
Sony Tv PFM-42 V1 doesn't show any picture or tv menu
This is a common problem with plasma tvs You did not mention whether you could generate any sound like through your dvd player or something like that. Whether you have audio or not makes a difference on which board may be causing you the problem. Just because it does not have a picture for tv viewing does not mean it won't produce some type of sound through your av1 input. Try it and I'll try to be more specific.
DVD sound but no picture...after pushing progressive scan button
desactivate the progressive scan or if u don't know how to do it, just do a reset on the dvd player.
DVD problem
on your dvd/cd drives you have to have the audio cable going to the motherboard, Here is a picture of what it should look like. tell me what you think. http://support2.jp.dell.com/docs/storage/7519c/dvd10.gif
Samsung DVD M105
Try to service your dvd to a technicain or change your audio wires. If not successful, maybe your DVD appliance's chipsets are defective
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
