Computers & Internet Logo
Anonymous Posted on Apr 11, 2012
Y can i not log in
Wot his the problem
Anonymous
Level 3:
  • Master 525 Answers
  • Posted on Apr 11, 2012
Anonymous
Master
Level 3:
Answers
525
Questions
Helped
130768
Points
1330
Where is the WOT relay for a 2004 Ford F-150 5.4l
wot = wide open throttle, (that is TPS sensor not a relay.)
why not state a problem or a goal or job first so the helper can be on the same page.?
the whole thing is here, log in and read.
I speak EFI, and even have done custom ECU,(megasquirt) installs and turning, so I can help if you tell what's up doc?
https://eautorepair.net/Marketing/Default.asp
What psi should my 2003 suzuki aerio fuel pressure regulator supposed to run at?
what engine, in what country?
Each engine has its own EFI even gas and diesel
we can not guess what whats under your hood.
why not log into mitchell DIY and read it your self'
oops it asks same question.
the FPR is DYNAMIC and has 3 tests. not ONE .
the service manual covers all that, if you buy one,
  1. key on pressure
  2. idle
  3. and WOT< wide open throttle (same as #1)
and at full vacuum even less.
our engine is 2.0L and 2.3l j20 AND J23
MY CRUMMY BOOKS ONLY SHOWS. AT IDLE.
31.3-36.9 psi.
but, (physics 101)
IT WILL BE more at wot by about 6pis (at sea level)
and less at full vacuum.
its a 1 bar, FPR.
this device does 3 things.
regulates
and compensates for altitude
and compensates for induction plenum pressures(vacuum)
at all throttle angles.
make sure the vacuum nipple does not leak fuel or its bad.
1helpful
I have a jaguar 3 litre v6 x type 51 plate with an engine warning light on dash the car seems to b driving fine wot cud this be ? [email protected]
The engine light shows a fault has occurred. The recorded fault will be visible if you have the codes read. One of the most common faults is the MAF (mass air flow sensor) this sometimes shows a wrong reading and logs as a fault, The light may go back out after the engine has completed another self check - if there is no ongoing fault. Get the codes read to be sure. .............. hope this helps
2helpful
Got a password on recovery management file on my laptop and i dont know wot it is but i've not changed it
lost windows password? There are 4 methods to recover windows password:
Method 1: Take a rest, and try hard to remember the forgotten password
Method 2: Try No Password Administrator Login Backdoor
Method 3: Reset password from another user account with administrator
credentials
Method 4: Do-It-Yourself (DIY) third party recovery tool
Such as Windows Password Recovery 6.0
I used it and succeed to log in.
Internet explorer wont let me connect to the internet at all!!
dont use internet exp. instead mozilla.. i hope it may help..try it..
4helpful
2answers
Can't get on to my bebo page
Hi i had that prob too you need to go to you auto updates and update you pc i did this and it worked so try that!
1helpful
Wen i log into my id on orkut a blank blue page is displayed
dont worry.Its a bug in orkut only.It wil be fixed soon.Till then use "m.orkut.com" its the mobile version.Although you wot get all features.Bt stil something is better than nothing.Right ? all the best
Acer aspire 1800 has no backlight lighting up and it has aband going across the screen at the bottom,i have put a new converter in and still same problem.
your LCD needs to be replaced /try logging to system setup if u still have the same display get the LCD repaired but wot i'll suggest is get it replaced
X box 360 mtu failed
First learn how to type so that people can understand what you are saying. Then post the error message that you got and exactly what it's not letting you do.
Grand Canyon Tech
Grand Canyon Tech
