SOURCE: my mitsubishi tv made a pop sound then the screen
Three Mitsubishi lamp replacement videos for Projection DLP HD televisions.
No one has made a video for you specific model yet, however.
Mitsubishi Lamp Replacement for Enclosure 915P049010 Osram
MITSUBISHI 915P027010 DLP Lamp Replacement Video/Guide
MITSUBISHI 915P026010 DLP Lamp Replacement Video/Guide
SOURCE: mitsubishi wd-57734 heard loud pop screen has gone
It sounds to me you have a Lamp that has exploded,
That Lamp and housing will cost around $300.00 or so. I am pretty sure that will fix it. Most of the Lamps are located on the back of the unit and is accessible through a door. Once removed, you should be able to get the proper part number off the Lamp Housing and call Mitsubishi to order the proper one. Their Parts Department Phone Line is 1800-553-7278.
I hope this helps,
Skyassoc
SOURCE: i have 60 inch mitsubishi hd DLP flat panel
If you see absolutely nothing on the screen then you may have a problem with the Lamp unit. If you can see around the back of the TV look to see if there is a vented opening with a noise of a fan and a rather bright light. If you see there is no light then try a reset (hold power button for at least 10 seconds). Turn the TV back on and the green LED should flash for a bit. If you still have no picture or video of any type (completely black screen) and have sound only you probably have a bad lamp. These lamps are around $125 or so and can be bought on Amazon or other sites that sell these parts. It's fairly simple to replace but make sure that the tv is unplugged and securely re-install the access door. Hope this helped.
SOURCE: I have the Mitsubishi WD-65738
Tv "LAMP" LED light indication on the tv frame word light up or blinking LED light.Check the tv projection Lamp first.The tv projection Lamp might litterly broken into glasses sharts itself.The tv projection lamp still intact,still should be change too though.After the tv projection lamp has been change the tv should work now.If still have problems the board that call the Balast board probally dead too.Becauuse this Ballast board only jobs are to help to ignite and keep tv projetion lamp light up and to work only.
