Question about Goodmans GTVL19W17HDF 19 in. LCD TV
Gtvl19w17hdf wont switch on
Get red power light, goes green comes on with white screen nothing else have switched on and off various times same thing happens no picture. is it ready for the bucket,or is it worth repairing
    Top Expert:
  • Goodmans Master
  • 14,553 Answers
For a 19 inch set the answer may be retirement---but have you tried to unplug it and or the box if used for signal for a while and plugged back to see if a reboot cures it(set will try if unplugged a while to do this)?
You might also call Goodman's customer service to see if the set has a hard reset done with the remote or even a software/firmware upgrade available.
What have you got to lose by trying?
Posted on Apr 11, 2012
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 58 Answers
SOURCE: Picture on my LCD TV takes 20 minutes, literally, to come on.
pannel failure. the lines will become perminent.
Posted on Dec 07, 2008
Wiring diagram for 220 volt light with switch
ok here goes first what do you want to do? replace switch or what, all 220 volt lights have a switch, plug has 2 hots( one red-one black), then you have a white and a green, red and black are power, white is neutral and green is ground.whit goes all the way through to light, so does the green, switch controls power so red on one side of switch and black to other side, hopes this helps
Oct 15, 2011 | Home
Utilitech Wall Timer #0192773 does not switch landscape lights on? Replaced Intermatic that had 3 wires. Black to Black, blue to black and red was capped. Utilitech came with 4 wires - black, white,...
Old timer: Intermatic EJ500 & ST01C timers have a battery. Battery operates the clock motor. Red wire is for 3-way circuit [a hallway with 2 switches is a 3-way circuit].
Utilitec timer, clock runs on 120Volt circuit instead of battery. So clock has to have power.
How to connect wires:
Black timer wire connects to hot wire from breaker box.
Red (or blue) timer wire goes to landscape lights.
White timer wire connects to white neutral wire [or if no neutral is available, connect to bare ground wire].
Green timer wire goes to bare ground wire.
How to find black hot wire and white neutral wire inside box
: Disconnect and separate wires so you can test. Use ordinary tester. Power is on. There is only 1 black hot wire inside each electrical box. Test each black wire to bare ground until tester light comes on > that identifies the black hot wire. Next, test black hot wire to white wires until tester light comes on > that is the neutral wire. Exception: This test does not necessarily work with 3-way switches since they reverse each time switch is thrown.
Sep 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have three house wires supplied- white, red, and
make sure power is off before working on the fan wiring ..(trip circuit breaker)
here is what the house wires are
1. black is hot (power) all the time .. its normally connected to the black wire of the fans speed control switch .. that is normally operated by a pull chain ..
2. red is the same power as black except it comes from a wall switch .. this would be connected to the blue wire in the fan (that goes to its light) .. that will allow you to turn the light on an off from the wall switch ..
3. white is neutral .. it connects to both white wires inside the fan .. one goes to the fan the other goes to the light. .. if there is more than one light bulb then there will be more white wires .. hook them all together and to the white house wiring ..
4 then there is safety ground .. usually green or bare copper ... that is connnected to either a green wire inside the fan or bolted to the metal of the fan (often a green bolt is provided) .. the green wire is not required for the fan to run but is required as a safety to make sure no one gets shocked on the fans metal parts ..
after you wire the fan ..then turn on the wall switch .. if the light doesnt light then pull its pull chain until it does .. you can then tie up or remove that chain to prevent anyone from changing that position since you can now control the light from the wall switch you dont need that chain anymore .. the fan should come on slow med and high then off .. each time you pull its chain ..
Jun 06, 2010 | Hampton Bay 24002 Ceiling Fan
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Have hand control wireing problem ,,,, need to know what color wire does what ,,,, got the left hand control to wire up on a older bike,,,,, hooking up trun sigals and head light control,,,,what color...
This information applies to the vast majority of Honda motorcycles. Colors for the right handlebar switch are: Grey sends power to the turn signal switch. Light Blue goes from the turn signal switch, to the right turn signals. Orange goes to the left turn signals. Light Green goes to the horn button.
The left handlebar switch: Yellow With Red stripe goes to the starter button. Black wires take power to the headlight switch and the kill switch. White goes to the headlight low beam, Blue to the high beam. Brown / White goes to the tail light, running and instrument lighting. Black / White comes from the kill switch and delivers power to the ignition coils.
I hope this helps.
Nov 06, 2009 | 1982 Honda VF 750 S
I'm replacing a single pole light switch with a timer switch and the timer switch comes with a hot (Black) and a Load (Red) as well as the netural (White). My question is how to wire it up. Does the white...
It all depends on how the light on the pole is wired. The switch you have is meant to interrupt the power between the circuit breaker and the light, just like the switch does now. The new switch uses power to run itself, so you need an additional wire. Usually the lights on a pole have the power coming in on top, and a wire coming down for the switch - black and white. Lets say there was no switch - on top of the pole there would be a black wire going to the hot, or center contact on the pole light, and the white wire would go to the ground, or outside of the bulb. If (BIG IF) things are wired like they are supposed to be, there will be a black wire (hot) coming in from the breaker, down the pole, instead of going to the light. The switch you have in place now interrupts the power so you can turn it off/on. Then when you turn the switch on, power goes up the white wire to the hot, or bottom of the bulb. Theoretically, there should be another black wire going back up to power the light once it leaves the switch. People normally use regular wire, which has a black and a white inside a plastic casing. So, bottom line - you need to run a red wire from the light to the new switch, hook the white wire up to the ground. So: power coming in on top goes down pole to new switch to black. Red wire hooks up to pole light where it is now white, goes down pole to red on switch. Old white wire gets unhooked from light on top, and hooked to common (ground) on top.
Aug 31, 2017 | Globe Electric Globe Indoor/Outdoor Lights...
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
Wont turn on
.........same problem.....
only my new hard disk worked...
Aug 06, 2008 | Sony Playstation 3 (PS3) Console
Goodmans GTVL19W17HDF 19 in. LCD TV Logo
176 people viewed this question
Top Goodmans Televison & Video Experts
Ekse
Colin Stickland
Colin Stickland
martin hogg
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
