My sticker on the bottom of the computer is gone and i need to find my serial number.
SOURCE: find the serial number of satellite m35x series toshiba laptop
the serial number can also be obtained from yours laptop's bios settings, depressing the F2 key on startup should take you into your bios settings
SOURCE: Acer Aspire 5315-2153 Serial number
Sometimes a serial number will be imprinted on a receipt, depending on where you bought the computer...or on packaging that you might have saved...
I've seen suggestions that it might be possible to locate it in the cmos/bios setup, but that doesn't seem too likely to me, and if you found one there, it's hard to believe it would be the same as the production ser. #.
You could try sending a support request to Acer, describing your situation... they might have some trick to locate critical info like hitting esc or F2 as it boots, but it may scroll by too quickly to read...
SOURCE: Lost serial # for a Gateway notebook Model MX 6425.
Here's one link to Gateway support for your notebook. If you may have saved a receipt for your notebook, sometimes the serial number is encoded on the receipt. Otherwise, perhaps you have the original packing box it came in stashed away somewhere. There's a label on the box with the serial number on it.
Otherwise, I'm not sure how to help you. Did you fill out any warranty cards or other info to keep track of the notebook when you bought it? Gateway support options here.
Good luck...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: i need the pc serial number for my ASUS x83v
hi pls you go to wavside asus service.com; opain IT resolve.IT resolve scaning your pc . he can find out your pc serial number or you check your perchage invoice. thanks
SOURCE: how do i find the serial number for my acer
it is located in the bios on the first screen
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
