SOURCE: Brother MFC 240C alignment problems
I have figured it out! I have a Brother MFC 240CN and I was having the same alignment problem and I followed the instructions from the printer prompt as well as the manual and it does not work.
So, this is what I did. I ran the alignment test print, then when it asked if it matches, I would say "No". And then I would pick number "8" to be the one that most closely matched "0" regardless if it did or not. I did this for the 600 and 1200dpi. Then when I ran the alignment test print again, it looked better! So I repeated it again and again picking "8" each time and it looked better with every test print. After about 4 or 5 tries, it looked normal again!
I hope everyone else with this problem will see this response and I hope it works too. I was getting so frustrated with this problem. Now I don't have to get it serviced or buy a new printer!
SOURCE: Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
SOURCE: My Brother MFC-465CN is printing text with alignment off and double text.
My Brother printer MFC-465cn is doing the same thing. I have workaround / worked-around it by disabling bi-directional printing. Then print is clear. It's as if the head is shifting an irregular amount on the opposite direction, like the head is loose.
Same for copies. If I use the PC interface to make copies, I can set the copy printing to be mono-directional, then copies are clear.
SOURCE: Brother MFC-440CN USB Printer double prints letters
Did you use Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine.
When they see it’s Generic Cartridges, it will print lines thru the words, mis-align the letters & put stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
