Question about Bulova Watch
How to stop chimes on Louis Valentin waterproof digital watch
This was a present from Spain it has 4 buttons, on the left side are the light and mode buttons and on the right start and reset buttons
  • RoJoSwed Dec 22, 2011
    First go to Mode button. Open Start Watch. When done - push the two buttons on the right side together at the same time, then you should have stop the chimes.
    Regards rojoswed@comhem.se
Press and hold the lower right button to display the date, then press the lower left button. If now all the weekdays are turned off, the hourly signal is turned off too. If the weekdays are turned on by this operation, the signal is turned on.
Btw: does anybody have some information about the vendor of these watches?
Posted on Feb 25, 2009
6ya staff
SOURCE:
I cant set the time on my adidas duramo watch. It says 'offset' and below it says '1H'
This has already been posted on Fixya, so I take no credit for it. I've put the original reply below :-
Directions for setting the time on the adidas duramo / furano / uraha / paruko watch 1. press and hold the SET/LIGHT button (upper left) until "light on" or "light off" is displayed 2. press the MODE button (lower left) until "hour" is displayed and the hour digits are flashing 3. use the START/STOP (upper right) button to increase the hour, and use the LAP/RESET (lower right) button to decrease the hour 4. press the MODE (lower left) button again and "minute" is displayed and the minute digits are flashing 5. use the START/STOP (upper right) button to increase the minute, and use the LAP/RESET (lower right) button to decrease the minute 6. press the MODE (lower left) button again and "second" is displayed and the second digits are flashing 7. use the START/STOP (upper right) button or the LAP/RESET (lower right) button to set the seconds to "00" 8. press the SET/LIGHT (upper left) button to accept the changes
Aug 31, 2017 | Adidas Watches
I have a watch that I got from Sears Canada?. I need to know how to change the time. I got it in the summer of 2012. It had 4 buttons, mode (top left), indiglo (bottom left), set (bottom right), and s
My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers
Nov 04, 2012 | Watches
I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Sep 14, 2010 | Watches
    How do I turn the alarm off on a Athletic Works, AW60442W
    I have the AW21312W, which has 4 buttons:
    1. Light (Top left)
    2. Mode (Bottom Left)
    3. Start/Stop (Top Right)
    4. Lap/Reset (Bottom right)
    To turn the set alarm off, push buttons 3 and 4 at the same time, the alarm icon should appear or disappear
    To turn off the hourly chime, press button 4. While holding it down, press button 2 and the days of the week disappear. The chime is now off. If you want the chime, press button 4 and hold while you press button 2. When all the days show, the chime is on.
    Apr 02, 2010 | Watches
    Have anAqualite digital watch - and no
    Most digital watches set by holding down the mode or restart button until the display begins to flash. You can then cycle through the display and set on the right time.
    Sep 17, 2009 | Watches
    Trying to set time on nike watch
    1. Press the bottom left button(MODE) to put on Time mode.
    2. Press the LIGHT button (ADJUST/LIGHT) for three seconds.
    3. Press the MODE button to select what you wanna change, be it hours, minutes, or seconds.
    4. The upper right button (START/LAP) is to move a number up, the bottom right button (STOP/RESET) is to move a number down.
    5. Press the LIGHT button to finish.
    Mar 13, 2009 | Nike Watches
    I cant set the correct day on my digital watch ,The watch has CG onit and is WR 100FT
    press mode 3 times to get to time set. then press reset to choose (hour, minute, seconds, day, month, date) and press start to change them. press mode again when finished.
    Oct 16, 2008 | Freestyle Digital 79801 Watch
    Can't reset the time on digital watch
    I found the solution at http://www.watchliquidators.com/fossildir/Nike.asp
    Hold down the button at the top left (the light) for about 4 seconds. The second part of the time will start blinking. I tried this before, I'm sure, but I must not have noticed the blinking and thought nothing was happening.
    Once the seconds numbers are blinking, push the top right button (Start/Stop) to move to the hour or minute. Push the bottom right button (Lap/Reset) to change the time. When you're done, push the top left button (Light) again.
    Mar 22, 2008 | Watches
    Timex 1440 sports digital watch time setting
    1. Press and hold the mode button until it starts to blink, then release.
    2. First the alarm time will come up.
    3. Press the mode button once to get to the time and date.
    4. The seconds will flash first.
    5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
    6. Press the lap/reset button to change the values.
    7. When done, press the mode button again to return to normal.
    Mar 09, 2008 | Timex 1440 Nylon watch
    Acqua Indiglo Digital Watch
    My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers.
    -AP
    Dec 04, 2007 | Watches
    Bulova Watch Logo
    919 people viewed this question
    Top Bulova Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Anthony Ward
    Anthony Ward
    Chan Sun
    Are you a Bulova Watch Expert? Answer questions, earn points and help others
