SOURCE: How do I set my Panasonic Lumix DMC-LZ2 Digital
You can set the megapixels and the quality but not the dpi. DPI is a setting for printers and scanners.
SOURCE: Should you use an 8gb sd memory card in a
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
SOURCE: Hello, is the Panasonic Lumix
According to the published specs for the DMC-LZ2, no. The DMC-LZ2 works with SD and MMC cards, not SDHC cards.
SOURCE: Can the Panasonic Lumix DMC-LZ2
True, the older technology Panasonic cameras don't support the higher capacity cards, in many cases.
SOURCE: lumix dmc-lz2 how high can
SD cards max out at 2GB. The manual states 1GB as the maximum size, but 1GB SD cards are getting very hard to find. You should be able to use a 2GB card.
