My behringer bx1200 bass amp was working fine, then one day when i tried to use the XLR direct out, i discovered it disconnected the signal to the speaker. the XLR and speaker work ok separately, but now dont work together. anyone have any ideas/suggestions?? thanks for your help
SOURCE: behringer djx700 pro 5 channel mixer
When you said radio I am thinking you mean receiver when you say stereo. Have you tried using your CD into the input that you are plugging your mixer into? If you get both sides , right and left of your CD then it is a problem with the signal from the mixer and we can work from there.
SOURCE: Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
SOURCE: Can I hook up 2 separate power amps to PMP3000? I
Better way... Connect the main speakers via the Speakons and then put a Power Subwoofer to one of the Monitor connections IF you are not using both stage monitors. If you need to kill the lows to the mains, use the EQ in the PMP-3000.
Use the EQ that is USUALLY on the subwoofer to kill the highs to the sub.
Lot less cables and hardware.
REMEMBER for equipment safety, power ALL interconnected equipment from the same source be it a receptacle or power distribution system.
Powering parts of a system from receptacles strewn around a room is asking for trouble of ground loops and ground faults.
SOURCE: I've got a Behringer Ultrabass Bb410 1200w 4x10
The cabinet is listed as a 4 ohm unit.
We would exoect to see four, 4 ohm speakers in series parallel or four 16 ohm speakers in parallel.
If teh unit seems to rattle, first put an audio oscillator into it and sweep the frequency. It is common for grilles and also logos attached to them to rattle.
Open the unit and power each speaker the same way individually for a test.
I suspect you will find either the grille or mounting hardware is actually doing the rattling OR possibly the wires inside are vibrating.
If the sound is a scratchy buzz, then the speaker(s) have probably had voicecoils damaged by overheating.
In this case, buy 4 new speakers and replace all. It is not likely to find replacements for the Buggera brand they put in these cabinets. Also the word on the web about that brand of speaker is not very good.
SOURCE: I just got a new Behringer BXL3000 bass amp and it
Common problem is to be using the wrong one of the two input jacks... one has higher gain. Also make sure both gain controls are turned up some.
