You need to import the photos to your PC to view them. There are two ways to do so: connecting a camera directly to the computer via USB (Universal Serial Bus) cable and by using a flash memory reader. Using the flash memory reader is considered the fastest method to transfer images. Some of the popular types of flash memory card readers are Secure Digital (SD), Compact Flash (CF), Memory Stick (MS), Multimedia Card (MMC) and Smart Media (SM). Here is how you can use the reader to view photos from your digital camera.
SOURCE: Help!?
maybe if you reset the cam and card, by formatting it using the PC rather than the Camera, save what pix u can then format, to format, goto my computer right click camera drive, usually F:\ press format, do a full format, dissconnect from PC then make sure u leave power on and format thru the camera, dont know if its possible top save pix but this shud fix the whole card issue
SOURCE: Transfer photos from Camera memory, to a card.
Take the card out and then you will be able to see the pictures in the camera's memory
SOURCE: Memory Card
make sure that the memory card you bought is a secure digital (SD) memory card. the kodak memory you have might not be an SD card.
SOURCE: cant get digital camera to work with memory card
have you tried to format the card before you start off with it
SOURCE: I have a X029 camera
hello sir can you tell me abut you cameramodels and date of buy and memory card size and which company?
