If you're running a Mac, when you try to install the LaserJet 1320, it may suggest that you use the driver set for "HP LaserJet 1320 Foomatic/pxlmono." Do not use those settings. I had to reinstall my 1320 recently and since it said that was the recommended choice, I selected it. If I printed just text, it worked fine, but even a tiny 50KB image would take 5 minutes to print. When I reinstalled it again, I selected the option "HP LaserJet 1320 series," and everything works just fine now.
SOURCE: hp LaserJet 1320 will not print multiple copies
This problem is caused by Mopier Mode being enabled by default. The idea of Mopier Mode is to minimise computer and network traffic by sending only 1 copy to a printer equiped with suitable internal memory. That stored copy is then used to produce the multiple copies. Most HP Laserjets do not have suitable internal memory and so only the one copy sent by the computer gets printed. To disable Mopier Mode:
Click Start
Click Devices and Printers
Right click your Laserjet Printer
Select Printer Properties
Click the Device Settings Tab
Scroll down to the bottom
If necessary, expand Installable Options
Click on Mopier Mode
Select Disable in the selection box that appears
Click Apply
You will now get multiple copies.
SOURCE: Model : HP LaserJet 1320
Hi, If that is the only light on (blinking or not), then you probably have a paper jam or a door open somewhere on the printer. Make sure both doors are closed securely at the back of the printer. Make sure that the toner cartridge is secured inside the printer. You not only have to just insert it, but you have to insert it until you can feel it lock into place. Make sure there is no paper jammed inside the printer or inside the rear doors. If you have a blinking light AND the power light is ON, press the GO button. This is also a sign that a complex print job was sent that max'd out the installed memory. Hope this helps!
SOURCE: hp laserjet 1320 printing blank pages
check printer door, there is a small plastic piece wich pushed down (to open) lasser scaner cover. if this piece is broken you can get blank page
SOURCE: printer only prints one page at a time
re- install the drivers from HP.com for the newest ones.
SOURCE: how do i reset my hp laserjet printer 1320 to its
It may be a defective cartridge regardless of its age. Did you remember to remove the pull strip on the cartridge? Is it getting more faint as you print more? If yes, replace the cartridge.
