I am having the IBM X3200 server. An external wd hdd drive. Driver is not listed in the drive letter. But the same drive is listed to to be removed safely.
SOURCE: Hello Sir, I need drivers for
What the paltform's dirvers you want?I have the Linux drivers of IBM System 3650,including the RAID tools etc.The difference of both server hardware is not too much.Maybe you can use it too.
Here is the drivers of website(in Chinese):
http://www-900.ibm.com/cn/support/download/driver/prosupport?category=13516&docordown=down
SOURCE: I have IBM X3200 M3
You can install the windows 7 on this server. But you cannot do it from the server guide since it will not contain. Try to install as normal method and check if the controller get detects . If it detects you can install it. Otherwise you need find the driver for it.
Thanks
SOURCE: i have a ibm x3200
is it with that particular software or any software you try to install?
if its with any software you try to install try different ram or say you have two rams take one out aand try with one ram then switch slots and see,to me it seems more of a ram issue,if ram aint the issue then try same software of a different disc or download it scan it and try to run it,
SOURCE: Server X3200, when i puched to
Hi!
You can contact the technical personnel of your provider where you purchased the server since its under warranty. Does it function properly when you purchased it? Do you upgrade memory, or hard disk?
thanks
SOURCE: i need ibm x3200 m3
Hello dear all,
I need to install more memory in my IBM x3200 M3 , plzz please send me the sequence , that i can upgrad my server.
Regrds
Ehsas
This solution worked
It needs a new drive letter. Try this,
go to control panel -- administraive tools -- computer management -- disk management
Find the drive and right click on it. select to change the drive letter
Thank you all.
