Panasonic Lumix DMC-FH27 / DMC-FS37 Digital Camera Logo
Joseph Posted on Apr 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
System error Zoom
The lens will not retract completely when camera is off. When on, it moves several times and then I get a message on the LCD that reads System Error Zoom.
CameraR
Level 3:
  • Panasonic Master 4,738 Answers
  • Posted on Apr 14, 2012
CameraR
Panasonic Master
Level 3:
Answers
4738
Questions
Helped
1194625
Points
12483
Lens errors (system error zoom on Panasonics) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
5 Related Answers
Anonymous
  • 11967 Answers
  • Posted on Jul 17, 2010
SOURCE: I have a DMC-ZR1 camera. Having problems with
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Aug 07, 2009
SOURCE: camera focus error
there is a small logic circuit that controls the motor that retracts the lens and a sensor that tells it the lens is retracted, it is a lens position sensor, one of these two components is most likely defective, the thing is there are no consumer service info provided by panasonic, they will not sell you parts either, the camera is a mystery to take apart and repair without the tech manual which u can't get, so u see the delima here, u must either have this camera fixed by a panasonic repair station or see if it qualifies for a upgrade exchange program for a newer model.
Anonymous
  • 66 Answers
  • Posted on Aug 03, 2010
SOURCE: upon trying to turn camera Panasonic DMC-ZS3 on,
I don't know that I can help you fix it, but I can try. Here are my thoughts... Check the battery first. If it's like a normal battery, like AA or AAA batteries, replace them and try turning it on.
If it's a flat lithium battery that you recharge using a power cord that plugs into the camera, you might want to buy a new one. Charge it fully over night and try powering the camera up in the morning.
You never mentioned what the error message was! So I can't help you there.
Next, you might try connecting the camera to your computer and see if it comes up. Also, check with Panasonic and see if there's a way to reset your camera. Maybe there's a way to do a software reset. Also check to see that there isn't a downloadable software upgrade or patch available. Lastly, you may want to consider Panasonic customer support/technical support, they may be able to better help you diagnose the issue with your camera.
I have a Lumix too. I have an DMC LZ10, my daughter has a DMC TZ3. They're similar in many ways, and yet they're different in many too. Mine uses AA batteries, hers uses a flat lithium rechargeable that uses a power cord. The internal software is pretty much the same (sort of). Enough so that I can work the settings on hers without having to reference the manual.
As a computer tech, my first impressions are that you're having either power issues, or software issues. Eliminate the variables. Start with power and work your way out from there. If it behaves the same with any battery, you've eliminated the power issue. Now it's software. Simple enough?
Anonymous
  • 6831 Answers
  • Posted on Dec 13, 2010
SOURCE: error de sistema (zoom) Lens don't close and
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
t00nz
CameraR
  • 4738 Answers
  • Posted on Feb 20, 2011
SOURCE: I have an FS15 and
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
How can I rectify the "zoom error" message on screen - also the lens will not retract either
Hello
Unfortunately a "zoom error" message is not something that you will be able to fix. This error indicates a system failure (apparently your lens is damaged, since it will not retract) and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
17helpful
4answers
System error: zoom message with Panasonic Lumix FS15 camera
I had the same problem, i switched the camera on in capture mode and zoomed in and applied a little pressure to the lens which made a slight click but retracted and has worked fine since. I may of just been lucky but the camera is fully functional again, could be worth a try.
9helpful
2answers
Olympus SP-570UZ-zoom error
Had 570UZ for 2 weeks and "ZOOM ERROR" occured. Seemed hopeless. Changed batteries several times, bought new Alkaline.
No change. Finally decided that it is probably a connector problem.
Turned Camera Off. Held Camera by the lense barrel. Held palm of other hand and thrust the back of the camera ( LCD side) into the
other hand. The idea being to jostle the camera contents without cracking the LCD. Did this a couple of times, turned camera on and it works fine. At least for this evening. At least for now it seems like a classic component connector problem somewhere inside the camera.
10helpful
2answers
Panasonic dmc-fz5
I posted a solution yesterday on Fixya, but can't find it. Same problem, same camera, solution reached on Feb 10 2009 after a couple days of frustration. I gently wiggled the lens by pushing my fingers one on either side (not the outer ring, but the inner ring, but keep your fingers off the glass part). It moves perhaps a fraction of a millimeter, but it moves. After I did that, the problem went away. It's hard to describe, just a gentle 3 or 4 times push on either side; you may have to change finger positions to get the movement. It apparently only takes this to get the lens back on track. Good luck, it's a great camera. Lee
1helpful
Zoom will not retract
Dear Grammie,
You have either experienced a lens error or your zoom dial is broken (both usually caused by some sort of impact damage, but which can be spontaneously occuring).
Look for an error message on your camera's LCD screen such as "E18," or "lens error restart camera." If you do not see a lens error but simply cannot retract your zom lens (go into wide angle mode) via the zoom lever then it simply maybe a broken command dial. Either way, however, you will need to have the camera serviced in all likelihood. Call tech support at 1-800-828-4040 M-F from 8 am to 12 midnight EST and Saturdays until 8 pm EST. Hope this helps.
Sincerely,
HeavyDLB
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Lens not retracting
if the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
5helpful
3answers
Zoom Error
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
1helpful
Error message now showing
Does the lens extend and retract as normal?
If so then the internal drive gear for the zoom / focus has been damaged and will need to be repaired/ replaced.
If the whole lens will not move or is stuck then it needs to be removed, stripped and re-assembled.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
